sqeaky front end
Car: Camaro z28 1500 Truck Honda CBR900rr
Engine: 305 HO.
Transmission: 350 turbo
sqeaky front end
Hey all,
I was driving my 84 Z28 around last night, that I notice the front end sqeak's a bit... Where should I start looking to get her to quite down.. I know I need to change the shocks, but what else. Can I spray the springs?
TIA
TIA
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
probably your swaybar bushings, but like on any car with that many years on it I'd suspect anything and everything made out of rubber. Best bet would be to replace the swaybar bushings but another solution would be to unbolt em, clean any rust from the swaybar itself, wipe the inside of the bushings clean, put some greese on em, put it back togather and see if that quiets it down.. BTW this post would do better in suspension.
Engine: 305 HO.
Thanks you so much and sorry I got this in the wrong section.. If im going to do all that work should I just replace all the bushings?
you could if you want, they probably are quite dry rotted by now anyway but try what i suggested first, simply remove em clean em up greese em and reinstall and see if that makes the sound go away. There are 2 caps, one on each side of the swaybar, a total of 4 bolts in all, its not much work, replacing all the bushings get somewhat involved.
Terrell351
06-13-2021 01:13 PM
