Stock sway bars vs. Aftermarket?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 82Z28
Ive got a 82Z28 and was just wondering about the stock sway bars on it, I mean are they any kind of good compared to say an aftermarket brand like Spohn or are we just pretty much talking a weight difference here?
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I'd just steal some bars off a WS-6 or an IROC. Most after market bars are something like 36mm hollow and 22/24mm solid rear, which I think is the same as those cars. Front bars has to be from a 3rdgen, rear bar can be from either 3rd or 4th gen.
Ben
Ben
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
That pretty much covers it
If you can find a 36mm front bar grab it and you will have all that you need up front. In back you want a 24mm in most cases (stock springs), but the 22 is also good. One more thing
SHOCKSSHOCKSSOCKSSHOCKSSHOCKSSHOCKSSHOCKS
![yup](https://www.thirdgen.org/forums/images/smilies/yup.gif)
![i agree](https://www.thirdgen.org/forums/images/smilies/iagree.gif)
Car: 82Z28
theres nothing wrong with the stock ones that are on it now i just didnt know if they were inferior to aftermarket ones or even later model 3rd gens?
1 Post
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have an '89 RS, stock sway bar front-30mm, rear-19mm.
I found an '86 IROC and took the 34mm front sway bar and the 24mm rear sway bar.
DRAMATIC IMPROVEMENT!!
Also intalled a spohn HUGE wonderbar, and 3 point strut tower brace from Edelbrock. Handles great!
1 Post
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi All,
I went though this upgrade last year at this time. I went with
sponser Top-DownSoutions.com and here is what I got.
23mm rear sway bar
34mm front sway bar
Front sway bar bushing
Rear Sway bar bushing kit
Four of these
End links
And these because my car did not come with a rear sway bar
Chassie Link Mounts for rear sway bar
This setup in tandom with my BF Goodridge 245/50vr16 TA tire are a great handling package. The car is just fun to drive especially in the mountains. Those curves got strighter and faster. Were talking about G's here.
I also have the TDS wonder bar. BMR Struct tower brace, Spohn sub frame connectors, Spohn lower control arms, Spohn track bar and Ebach Pro Springs. So before you add the big sway-bars the chassie should be reinforce. Doing one with out doing the other is a big mistake.
23mm rear sway bar
34mm front sway bar
Four of these
End links
Car: 82Z28
anybody use the TDS sway bars? I was debating between those and just pulling some off of an 86IROC like mentioned above
IMO, the 36/24 combo, under most circumstances, is more than adequate. They can be found on some 89-92 Camaros and some 86-92 Firebirds. Yank'em, paint'em (or powdercoat'em) and you're good to go at a very reason price, ie, cheap. I'd throw on some 1LE poly end links (10221779) and some greaseable poly bushings (TDS or Spohn)--or you could use the higher durometer GM rubber bushings, 14094389.
JamesC
JamesC
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
4RCEPWRD, first I'd like to say glad to see someone from my area, thats a first on here
Secondly. I belive the swaybars on the early z's are smaller diameter then the later models. I'd suggest measureing what you have, largest stock up front is 36mm, largest stock rear is 24mm.
If your on a budget and dont have these, I'd hunt around and find some.
If you have no budget, and like taking these no-sense roads around here at max speed, I'd suggest some aftermarkets. Along with that id do some of the other items listed in this thread.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Car: 82Z28
Dale, Hey thanks man I was beginning to think Id never run into anyone from Arkansas on the boards but glad to finally see someone from the area is also on here, but anyways ive already got the spohn sfc's. tds wonderbar, tryinng to decide on the spohn lca's(boxed or adjustable any opinions) on the lca's if i get new springs will i have to buy the lca relocation brackets due to lowering of the car? but i was just wondering about the sway bars but i think my questions on those has been answered thanks guys
Engine: 350 S-TPI
cool, another.
Was iced in here all weekend.
Technical post, I found upgrading the suspension to grip on dry payvment decreased the grip on poor payvment.
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
1 Post
Originally posted by techno101
well here in Fayetteville, we're snowed in!
You lucky dog. I'm here in Cary, my boys wants snow. LOL
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
