245/50/16 or 255/50/16?
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
i am having trouble deciding tires fro my car will the 255's fit with minimal rub or am i stuck with the 245's..is anybody running this size....mine is a 92 rs with stock 16" rims...thanks
Car: Z/28
Engine: 355
Transmission: Turbo 400
If you are running 16" x 8" rims, 255 will fit with just alittle rubbing at full steering lock on the inside fender wells. A big hammer will fix that. I run 275/45-16" on 16" x9.5" rims with no problem.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
I just got some for my car, 91RS, that are 275/50/17 rear and 275/40/17 front on SLP ZR1 style rims (17x8). The ones on the back fit (I had to roll in the lip on the inside of the rear wheelwell) and the front ones fit (but rub at full crank when suspension is compressed). Its looks pretty wicked. I say to go with the 255s (if its within ur budget) cuz the wider the tire the better it looks...
1 Post
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Thirdgens that orginally came with the 245/50r16 tires used a different steering box that limited the lock to lock turns and the maximum steering angles. So if your thirdgen did not come with these type of tires, then you will have rubbing on the inner frame rail whenever you turn the wheel all of the way to the stopsl.
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
My 91 RS had the stock 235/55R16 on it and they rubbed when fully turned. I put the 245/50R16 on and they don't ever rub.
Axle/Gears: 3:08
I just ordered the falkens 255/50/16 I called edge racing and that is what they suggested also..the coolest part is they were only $308...thats awesome for a y rated tire of that size and brand...thanks guys i'll post when i get them on and let you all know how they worked out...
Car: 91Camaro RS
Engine: 305TBI
Axle/Gears: 3.08
dwillis: I think you will be happy with them. I have the exact tires on my car(except mine are 245's). Compared to the stock Eagle's that were on there, I noticed a difference, especially in the rain.
My buddy has an 87 Grand National that runs low 11's and he swears by them. Says they hook great and wear awesome too.
Car: 1987 Black IROC-Z (SOLD)
These two sizes were introduced by Goodear in 1984 for the Camaro/Firebird and Corvette. They were called "Gatorbacks" and were original equipment (OEM) tires. These were the largest size tire for that time on US production cars.
245/50/VR16 on the Camaro/Firebird only on certain models.
255/50/VR16 on Corvette
Later other tire companies also introduced these sizes for the replacement market.
Axle/Gears: 3:08
got my tires guys...they are awesome they dont rub at all and are great in the rain...thanks for the advice....i think i need an alignment now because when i'm driving the car kinda feels like it is trying to steer itself and i have to kinda fight with it to keep it straight..it kinda veers off one way or another and didn't do that before so i will deffinatly have to get that checked out..i also noticed my right rear wheel cylinder is leaking brake fluid so thats another project for next weekend...oh yeah i went with the 255/50/16's
Axle/Gears: 3:08
Originally posted by Shagwell
my rears alone are over $308...they probably hook alittle harder though...
Axle/Gears: 3:08
well i took it to gateway today for an alignment and they informed me that my tie rod ends,control arm and center link were is so bad shape that they couldn't do the alignment....so theres another project for me...because im not paying 1.2 million dollars for them to do it
Axle/Gears: 3:08
i got the Falkens...i definatly recommend them...and the 255/50's
fit perfect and dont rub at all
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
