Tires for 18-9.5 rims...275-40-18 or 275-35-18
Car: 1992 Camaro
Engine: 350 miniram
Well I finally got my dream set of wheels, brand new I might add. They are the C5 Corvette magnesium 18-9.5 rims, and I got 4 of them instead of running the 17/18 setup. I didn't have a scale handy to weight them but boy are these suckers light. I bet they weigh less than one of the factory 15's. I will weight them this weekend.
Now the corvette came with a 275-40-18 but thats almost an inch taller than the 275-40-17 or the 245-50-16 that are usually run. If I went with a 275-35-18 then its the exact same height. I'm kind of leary of running the 35 series because of such a short sidewall, and that the 40 series would give more cushion. If I were to only use them for the track then its a no brainer, but I really want to run them on the streets as well.
I have the Eibach Pro kit installed thats only about a 1" drop, and I also have a Autometer electric speedo that can calibrate for any tire size. So with all that said who is running these tire sizes and can give me some insite. Handling, comfort, rubbing, etc...
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I ran 35's(265/35/18) on the street but was stock height ride wasn't that bad unless the road was all ****** up
my car handled pretty good and I ran them at 40psi
Car: too many ...
I run 275/35/18 in the rear, no problems with daily driving before the tranny blew (of course, avoiding potholes and such). But IMO the 35 series tire mixed with a Pro-Kit drop will be too much fendergap for my tastes. Depends on what you like.
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
I am still waiting for my 18" foose wheels and i was gonna go with 275/40/18 rear and 245/40/18 front but i think i'm gonna switch to 245/45/18s up front, I have prokit springs, I think it will work out nicely but i can't really find any pics yet
What U think of that setup Crazy?
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
I got 295/35R-18s on my 18x9.5 C5's. Ride isnt that bad, even with my junk monroe shocks. If you are worried about a rough ride, put some konis in your car, I have them in a previos car. They will dampen even the worst of roads
COTM Editor
I am running a 285/35r18 in the rear and 265/35r18 up front and feel like these ride nice in the rear. Up front can be sharp on deep cracks and holes. It was dropped with a PRO- KIT, and crazyH is right there is too much fender gap, but switched to a SPORTLINE kit and now it is fine with no rubs - 18x9, 18x10.
Don't be affraid of the 35 series unless you roads around you are trashed and cannot avoid potholes.
Car: too many ...
Car: 91 z28
Engine: 350 tpi
you should get a 40 series tire all around it will look much nicer with the prokit. i found this pic and he has 40 series tires with a 1in drop.i think its powermites car not sure.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
