Shock and spring matching question
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I'm wanting to replace worn out shocks and possible sagging springs on a Trans Am (~130K mi), and I was looking at the KYB GR-2 (#236001 fronts and #343211 rears) shocks and Moog springs (#5664 front and #5665 rear). Are these shocks and springs a good match? The car doesn't need anything better than stock, so no Bilstein's or Koni's... just some good factory replacements. Also, should I get new spring isolators as well?
Thanks.
Thanks.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
good to go, they'll be slightly better than stock, but nothing too fancy...
get the spring isolaters too
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Eibach and Bilstein, get them, you won't regret them!
ambainb
04-25-2016 09:21 PM
