offset formula rims
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
offset formula rims
Anybody put front offset formula rims on the rear axle? I've got 16" factory alloy's and the front has more offset than the rear and I was wondering if I could get ahold of another set of front's, would the increased offset on the rear help with a loose condition?
I'm looking for someone that has tried this for first hand info! Not a bunch of theories! OK? Thanx! Sqzbox
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Yeah, increasing the rear track definitely seems to make the rear stick better around corners. I doubt the little bit of track you'd gain would be very noticeable though. I noticed a nice difference when I put my 4th gen rear in before I swapped to 'vette wheels. The rear definitely stuck better around corners with the added 3 1/4" of rear track.
The other advantage of running four front wheels is that you can rotate tires front-to-back then as well, whereas you can't put stock rears on the front.
Car: 1997 Corvette
You should send them to me Might not have the same problem I do now once I get my narrower rear rims on next season. Going from 18x9.5 to 17x8.5. Want the width, but don't want the extra inch of wheel
You shouldn't need those spacers, even with stock wheels. I didn't have them on my car and my car came with the aluminum rear drums and 16" TA wheels.
Car: 1997 Corvette
Re: Spacers
Originally posted by kurfbird
Spacers are only for 16 in rear drum (cast Iron) not aluminum
drum
drum
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I ran 4 fronts on both of my cars, 4 front GTA's and 4 front Formula wheels.
Gives a nicer stance, makes it easier to rotate tires, etc...
Car: 88 formula WS6
Engine: 305 Lo3
Zepher, When you put the 4 fronts on your 88 did you notice any improvement in the handeling? and what did you do with the spacers? I have the same wheels and would like to keep the car stock looking as I can. As far as trying to run it in autocross now, it's a joke! It's like someone squirted oil on my back tires at the starting line! The front end goes anywhere I point it but the rear
end is another story.
I can't really say that I felt anything different when I went to the 4 fronts, but then again I just drove it on the street.
The tires were different as well.
I just put the spacers in the garage somewhere.
rb85TA
26
09-14-2015 11:29 PM
