stock swaybar size?
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
stock swaybar size?
does anyone happen to know the stock swaybar size front and rear that came stock on an 88 iroc. i want to get new bushings but i dont know what size i need. thanks in advance for your help.
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Measure
Measure it ... make sure you measure at several spots .. at some bends it may look like it's 36 mm ... but in reality it may be 34
My guess would be 34 mm front ... an '87 or later Z28 at the junkyard had a 34 mm
rear hmm probably hmm 21
People correct me if I'm wrong
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Posted by me in FAQ:
https://www.thirdgen.org/techbb2/sho...threadid=59687
It should be a 34/24 like mine was but check your code.
Ed
Ed
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
