Removing engine cradle questions
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Long story short, I notched my engine cradle on the drivers side to try and get some LTs to fit. Turns out they werent for my car (bought em cheap from a guy at work). The hole is pretty big, and Im forced to replace the x-member rather than trying to reinforce it and hope for the best. Only thing is that the 383 isnt ready to bolt in yet, so I have less weight to put on the coil springs to take them out.
My main question is whats the best way to take out the coil springs without having to buy/rent a spring compressor? I have strut spring compressors, but I dont think they'll work.
And if I remember correctly, I have to take the A-arms, coil springs, struts and knuckles off and then just 4-6 bolts that hold the x-member in, correct? I dont have to dissassemble my brakes do I? I dont feel like messin around with wheel bearings just yet
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Removing engine cradle questions
https://www.thirdgen.org/techbb2/sho...ing+%2Bsprings
A-arms (at the ball joint) stay hooked to the knuckle which stays hooked to the strut which stays hooked onto the car. You will have to pull the swaybar endlinks off, and unbolt the brake lines that are bolted to the k-member in a couple of spots. You will also want to unbolt the front brake hose brackets so it will be easier to move the front control arms around. Then it's just 6 main bolts after the spring is out, and 2 triangle shaped brackets in the front.
