Will dropzone springs be higher?
1 Post
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Currently I have a set of newer Moog Springs with one coil removed on gtII 225/60/16 tires. Will a set of dropzone sprigns be lower, the same, or higher with a set of 255/50/16 tires?
Currently
Currently
I don't think anyone will be able to answer that, maybe stock moog springs vs. dropzone springs, but you already cut your moogs so if I were you I'd just buy them and try it, worst case unload them back in the for sale forum/ebay.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
A little bit lower one coil off a new spring is ruffly a 1 inch drop. the dropzones are 1.5 IIRC.
1 Post
Car: 91 Camaro RS
Currently, I have 7 inches of clearance at the lowest point of the front ground effect. Most people have posted a clearance of 6.5 to 8 inches with dropzones, so I'll probably stay about the same.
WhteRbt
09-21-2015 09:48 AM
