How much power can a unibody car take?
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
My brother in law tells me that my car cannot take alot of power because the body will twist. I want to put around a 450 horse motor in it. i know that subframe connectors are a must. i need some back up that says that thirdgens can take a certain amount of power. My car was up north and it has its fair share of rust but im going to take care of that.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With a rusty body it's hard to say how much power it could take. The body is the frame so if too much metal is now rust, there's not a lot left to provide stiffness.
The first thing I did when I bought my car back in 1999 to become a race car was install SFC. It wasn't until I was knocking on the door of an 11 second pass that I installed a roll bar (now a full cage).
When I had the roll bar, all I had for rear suspension was adjustable tubular torque arm, LCA and panhard bar. I fabricated some LCA relocation brackets and had the rear mounts of the LCA lower than the front. I don't have any interior at all so seeing sheetmetal problems is easy. After a season of racing like that, the floor behind where the passenger front seat would be was all wrinkled including the side of the driveshaft tunnel. All my hard launches were forcing the RH LCA forward enough to start wrinkling the floor. Shortly after that I switched to ladder bars which are attached to a crossmember welded to the SFC and I've never had sheetmetal problems again. I now have violent launches enough to yank the front wheels off the ground and even with a T-top car, there's no cracks anywhere in the roof line. Of course my car is nowhere near stock or street legal but it's still a production car converted to a race car not a tube chassis car.
SFC can go a long way to stiffening up the body. A simple 6 point roll bar will do the rest. Even a 14 second car could use a 6 point bar to stiffen it up. You can use swing out door bars to make getting in and out a lot easier.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you want a really nice setup and are that worried about hurting the body, provided it isnt really really rusted out, you *can* install both Spohn and Alston subframe connectors.
Im starting my new build soon, and have a unmolested 89' RS, rust free, the first things going in will be both sets of subframe connectors, I already have the Alstons and will be ordering the Spohns shortly, after both sets are installed i'll be getting some additional tubing and then tying both sets together, I HIGHLY doubt one would be able to twist up a thirdgen that this has been done to, cause it will pretty much be like a tube frame under the car.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres 2 questions there.
how much power can a thirdgen take without permant damage?
how much power twists a thirdgen?
the answer to #1 is: it'lll twist like hell on a launch, but a 450 flywheel hp motor wont hurt it.. you could make that at the rear wheels without a problem.
obviously it'll flex and become a "loose" car.. wont ever brake, but the doors will shake going down a rough street.... but if you're making that power anyway, toss a rollbar in it, and it'll stay stiff.
the answer to #2 is:
a stock 170 flywheel HP L03 can twist it hard if you put slicks on it.
i also should have clarified....its not going to be a strip car. Im setting it up for a good handeling street car, with occasional trips to the race track. From what i gather the body wont twist unless it hooks up, right? Also i was thinking about a roll cage, but im going to do that when i do my interior. but subframe connectors should work for now on a car that rarely sees the strip.
Car: 91 Camaro Vert
if its a handling street car, you'll want SFCs, a wonderbar, and a strut tower brace..
the car flexes when cornering hard too... most people wont notice it, but if you're trying to autocross or toss around some tight twistys, its very apparent.
Car: 91 Camaro Vert
also, the more abusive you are, the looser it becomes.
the car is like a paperclip... bend it once, its hard.. bend it again, its a little easier, and a little easier, and a little easier, and a little easier......
Car: 93 240SX
Engine: LQ9
Re: subframe connectors
Originally posted by Cam91z
Alstons and spohn sfc? How? Diff mounting points?
unfortunatly i wont be able to run either of those right now. i routed my exhaust differently. the muffler is located where the cat should be. My brother in law is going to make me subframe connectors. is there any way i can laterally brace the frame? one thing i was thinking of is the stabalizer bar above the panhard rod, making a nice steel tube piece. also i have a fully adjustable panhard bar, tube LCA's, wonder bar. i need a tubular torque arm.....
Originally posted by Z28*****
.... I already have the Alstons and will be ordering the Spohns shortly, after both sets are installed i'll be getting some additional tubing and then tying both sets together, I HIGHLY doubt one would be able to twist up a thirdgen that this has been done to, cause it will pretty much be like a tube frame under the car.
I've already done it and will try to post pics soon.
Car: 93 240SX
Engine: LQ9
Originally posted by Dr G
You don't even need any additional tubing, the cross bracing towards the transmission tunnel that comes with the Spohns can connect nicely to the cup of the Alstons.
Yeah but I want to add a tube in the middle and possibly one at the rear also
Car: 86 Iroc
Car: 1992 Camaro RS Convertible
Engine: 3.1
not sure who's car this is, but it seems to be a pretty good picture of what everyone's talking about. Hope this helps.
not sure if those "new pieces" are spohns, but its another point you could use yo stiffen the chassis
Iroc8t8
08-26-2015 08:14 AM
novaderrik
08-10-2015 12:44 PM
