Any use this SFC?
1 Post
Car: '85 Camaro
Engine: LG4 305
Any use this SFC?
http://www.swracecars.com/pdf/stockerparts.pdf
It looks pretty good to me tying the sides together.
Would love to hear other opinions.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Wow that looks pretty sweet. How does that cross bar work though. How would you drop the torque arm, driveshaft or exhaust? Guess ya really can't weld it in there.
Nevertheless, looks like it would really tie things together.
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I've seen those talked about on the boards before. From previous discussion, the only downside is that the crossmember will reduce ground clearance significantly because it goes below the driveshaft and exhaust
1 Post
Car: '85 Camaro
Engine: LG4 305
Wouldn't it then interfere with the suspension and drivetrain movement it is was underneath?
It would seem that it should go on above the rear, not below?
1 Post
Car: 1984 Trans Am
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
luvofjah
09-26-2015 08:28 PM
