Suspensions, wheels and exhaust all in one...
1 Post
Car: '85 Camaro
Engine: LG4 305
So if I've read it right you don't want your car lowered with long tube headers, but 17" wheels raise you higher?
Would it look dorky if I just replaced the springs with some that are stiffer, but don't change the ride height? Wouldn't want to screw up the headers by scraping them on the ground...
Jason
Jason
1 Post
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
What size tires do you have now?
The tire diameter for my 275/40-17s is roughly the same as my old 215/65-15 (something like that). So it didn't raise the car at all.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
17" wheels will do nothing to your ride height if you choose the same height tire.
275/40/17 is the same as 245/50/16 is the same as 225/60/15.
How much are you going to lower the car and with what long tubes? Some are worse then others.
You should be OK with a Pro-kit, but remember it might not lower you much from where you're at since your stock springs are 20 years old.
1 Post
Car: '85 Camaro
Engine: LG4 305
Yeah, my k-member has tasted asphalt already with the really old struts on it.
I just wish I knew up front how much lower the headers are going to hang...
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
my hedman s-bends tend to scrape every now and then on rough bumps, but i have old motor mounts and need new springs and shocks.
Running lt's and s-bends into straight true duals and summit mufflers, I have maybe 3 inches ground clearance at most in spots, but its temporary and only cost about 50 bucks top.
i'd think w/ a stock style cat-back system and a good y-pipe, you'll be ok.
longtubes aren't all that bad...wish my s-bends were shorter though...
