t-top roll cage
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
t-top roll cage
does anyone know how to put a roll cage in a 1982 camaro berlinetta with t-tops with out blocking the doors. any pics would help me alot
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
This is in the wrong forum. You should ask this question in the fab forum...
First off, are you doing a cage for the strip? If so, you'd be better off going with the 8-point rollbar from Summit or Jegs (can't remember which, one or both should have it) because they have regulations regarding rollbars for the track.
If your car is going to be a street car, you'll need to have a custom rollbar made. You'll want bars coming to the front area of your seats, otherwise the cage won't do that much good. Just bend them to run down low. They will still be there, but it will be easier to get into the car. Kandied91z has a rollcage in his old Camaro that is probably close to what you're looking for.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
You could use swing out side bars and remove them when you aren't at the track.
Thirdgen89GTA
11-26-2015 11:04 PM
tmork454
09-29-2015 06:33 PM
