Chassis Modification for stock height
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
I'm going to buy chassis and suspension parts like lca, sfc, panhard rod, strut tower brace etc.
I'm going to keep my car at stock height and I have no intention of lowering it in the future, it's more than low enough for me.
My future plan is to modify my car up to 500rwhp daily driver so I'm trying modify my chassis as powerful as possible to support that power safely.
My question is do I really need adjustable type lower control arms, panhard rod, strut tower brace etc. because from what I've read their function is to adjust the car properly after it's lowered.
If I buy non-adjustable parts would it be enough for me or are there another function of these parts other than adjusting the chassis when the car is lowered.
Also I've heard 3 point stb's only work in hardtop cars, when installed on t-top cars they tend to crack the windshield is it true? I have a T-top car should I buy a 3 point stb or just get a 2 point?
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I would buy adjustable regardless of ride height. Older chassis cars have chassis fatigue- especially unibody cars will twist and flex. Adjustable LCA and panhard will maintain perfect alignment specs where fixxed position products wwill not allow for needed corrections such as thrust angle change and sagging springs (or even different new springs.
500HP daily driver? Have you ever driven a 500HP car- once you have you learn real quick you don't want one for a daily driver.
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Re: Chassis Modification for stock height
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Re: Re: Chassis Modification for stock height
Originally posted by 91formulaSS
Does anyone know anything about this?
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Car: Agood2.8,
Engine: V6rsr,
Originally posted by John Millican
Not to change the subject but yes! I would like to have a 500HP daily driver. I have driven one as well.
PS I see from your bio you are in GA and you do Avionics. You happen to know the name Draden Ekas?
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
1 Post
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i had a 3 point on my car for about 8k miles. no sfc , and lots of other parts, never had a prob and i did plenty of spirited driving
Genopsyde
10-07-2015 08:35 PM
sailtexas186548
08-26-2015 03:32 PM
