spohn torque arm
Old 11-30-2004, 08:42 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
spohn torque arm
ive been doing some research on the spohn torque arm. its my understanding that they are the best. but just bolting it in? im sure theres someone out there thats welded it in. anybody with pictures? id like to hear some feedback about them. it sounds pretty good but just bolting it on sounds kinda sketchy.
Old 11-30-2004, 08:51 PM
25THRSS's Avatar
what? Why would you bolt it in? Sketchy? That's how your car came from the factory. Trust me, you want the ability to remove the rear and and transmission.
Old 11-30-2004, 08:53 PM
Kat
Kat's Avatar
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Its just bolts right in.. There is no need to weld it at all. If you do, and say your trans blows, how are you going to remove the x-member to remove the tranny? When Steve desinged the setup, he designed it with it being 100% bolt in. About the only thing he sells that have to be welded are the SFC's and relocation brackets. Thats about all I can think of at the moement.
I'm actually going to be putting his one for a t56 with a rod end in my iroc this weekend. If ya want I can snap a few pics.
Kat
Old 11-30-2004, 10:36 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Kat
lots of pictures
Old 11-30-2004, 11:59 PM
VILeninDM's Avatar
it's a bolt-in, but those are pretty beefy bolts
Old 12-01-2004, 12:31 AM
EvilCartman's Avatar
Car: '82 Z28
Yup, big beefy bolts. Here's the mounting setup on my Currie 9" with Spohn's torque arm. Big bolts all around
Old 12-01-2004, 02:40 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
yeah i love the big bolts, someone put the rear bolt in upside down(after some rearend work i suppose) so now i can't get my torque arm off without cutting the bolt
Old 12-01-2004, 03:01 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Kretos, You life depends on those "so called" upside down bolts. They are in fact NOT upside down. They are intended to slip in from the top so they will not fall out if the nuts come off. You loose those nuts off those bolts doing freeway speeds and you can kiss you butt gonight (and everyone in the lane next to you.)
Old 12-01-2004, 12:39 PM
Kandied91z's Avatar
yeah having my edlebrock snap on me even going slow was an uncomfortable experience, i couldn't imagine one letting go on the freeway.
Old 12-01-2004, 01:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
try this:
take the jackstands from under the rear.
stick them under the chassis of the car...
TADA! the rear is at the bottom of its travel, and you can slide the bolt out the top.... and up and up..... as theres LOTS of room... lol.
Old 12-01-2004, 01:58 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
LOL that's what I did when I installed my Spohn TQ ARM. But I put the bolt in that way for another reason... I was to lazy to try to spin the nut on from the topside.
As for welding the TQ Arm I'll mention the point that the arm is designed to pivot as the rear end adjusts for weight load or road conditions so it wouldn't be smart to weld the front, the crossmember has already been mentioned. Else you're going to end up with some major binding. As for welding the backs that's also not a good idea for the same reason... the back bracket wouldn't work out well welded either just for the fact thirdgen guys like swapping out rear ends from time to time.
Old 12-01-2004, 04:06 PM
KiLLJ0Y
Guest
Posts: n/a
umm for those of us that have the McLeod T56 (which if you dont know requires to take 1" out of the drive shaft and 1" out of the torque arm) what options are there for us other than completely fabricating a new one from scratch?
Dont Worry Dean, Don reinforced it pretty well but i was wondering if there were options in the aftermarket arena.
Old 12-01-2004, 06:16 PM
Kat
Kat's Avatar
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
E-mail Steve. He can make what ya want.
Kat
Old 12-01-2004, 08:18 PM
Car: 85 camaro
Engine: 327
do the bolts loosen often?
Old 12-01-2004, 08:22 PM
Engine: 383 SBC
Not that I know of, I checked them about 1.5 years back and they were tight still. I did notice my adjustable LCAs were starting to get loose on the adjustor part but once I put my gorrilla grip on it with a massive wrench it's been tight since. Guess I didn't tq them down hard enough to begin with. I would check them all again but since I haven't drove the car in a year I'm not to worried + it's snowing here now.
Old 12-01-2004, 09:49 PM
Kat
Kat's Avatar
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Not really. The torque arm to rear bolts you can really crank down on them. I haven't had one come out yet. AS for the jam nuts. Depends. Sometimes they do jsut because of the vibration of the tires bumps in the road blah blah blah. You can cure that by using a mild strength loc-tite on them.
Kat
Old 12-02-2004, 09:51 PM
Car: 85 camaro
Engine: 327
lets see some more pics!
Old 12-02-2004, 10:07 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
heres mine before it went in, very heavy peice big upgrade from the stamped steel factory one
Old 12-02-2004, 10:08 PM
JeffW's Avatar
Engine: 305 tpi LB9
very heavy duty stuff, very easy to adjust too
Old 12-06-2004, 01:01 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
it is nice but pricey to mee....what do you know i paid for it though
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
92rsvortec350
19
10-09-2015 09:39 AM
loud91rs
10-05-2015 10:05 PM
Nick McCardle
09-10-2015 08:36 PM
Quick Reply: spohn torque arm
