tire size help
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
tire size help
i wanna kno if any companies make a 275/50/16 or 275/55/16 tire. i wanna put em on mu 16x8 irocs on the back but i can only find 255. i want bigger. even a 265 would make me happy. side wall no bigger than 55 tho. any help whould be great
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
First off, when you say you don't want a sidewall bigger then 55, the sidewall is determined by a ratio in comparison to the width. 275x.55 is different then 265x.55
Tirerack.com can help you with who makes what size.
Re: tire size help
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
It would not be the best, but my dad talked to year one, and he is running 295s on an 8 inch wheel. Year one said they would fit, and he has not had a problem since.
Car: Formula
Engine: LO3 5.0l TBI V8
Transmission: WC T-5
thanx for all the info guys. i thought the sidewall was a ratio of the width but i wasnt sure. i think ill just stick with a 155 for the rears. id like to upgrade to 17x9 but i still want the iroc look and the 17s only come in x8
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
BF Goodwrench Radial TAs 295/50/16 on an 8 inch wheel is what my dad uses on the back of his 71 Formula. A guy at work had the same setup on a monte carlo.
Hotrodboba400
12-10-2019 07:07 PM
TheTraut88
09-07-2015 05:22 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
