Steering box rebuild
I highly recommend Circle Track Steering. They (He actually) are good, and inexpensive. $125+shipping (both ways). They are in Gridley, CA (Sacramento area).
http://www.circletracksteering.com/default.htm
Call Larry at (530) 846-3487
Price List
Effective 01/01/2003
NO CORES Required
PART # DESCRIPTION PRICE **
CTR-1630 16:1 Variable Ratio ¾-30 Spline O-Ring Fitting $ 160.00
CTR-1636 16:1 Variable Ratio 13/16-36 Spline Compression Fitting $ 160.00
CTR-1430
14:1 Ratio ¾-30 Spline O-Ring Fitting $ 160.00
CTR-1436 14:1 Ratio 13/16-36 Spline Compression Fitting $ 160.00
CTR-1730 17.5:1 Ratio ¾-30 Spline O-Ring Fitting $ 160.00
CTR-1736 17.5:1 Ratio 13/16-36 Spline Compression Fitting $ 160.00
CTR-1230 12:1Ratio ¾”-30 Spline O-Ring Fitting $ 230.00
CTR-1236 12:1Ratio 13/16”-36 Spline Compression Fitting $ 230.00
Rebuildable Cores supplied for rebuilding $ 125.00
Cores inspected and found non-rebuildable will be invoiced at regular price
Repairs to any Circle Track Steering, LLC Steering Gear $ 35.00 Labor + Parts
(Must be repairable)
All gears come with .165, .175, or .185 Torsion-Bar Valves Standard.
Pitman shafts and Rack/Piston Assemblies are wet magnafluxed.
Pitman shafts/Rack/Pistons are automatically replaced during any repair procedure.
Pricing subject to change due to variances in core costs and condition.
**Price does not include shipping, handling, or sales taxes**
Price List
NO CORES Required
CTR-1430
www.detroitspeed.com Somewhat on the expensive side but they offer rebuilds or replacements. They have a write up in GM High Tech Performance Jan/2005. Sounds good if you can stomach spending $500 on there steering gear. .............jt
Magman
09-13-2015 08:43 AM
backtothe80s
09-05-2015 12:39 AM
