How to "Fine Tune" my ride height?
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
I installed Eibach Pro-Kit springs, Tokiko struts along with eighteen inch IROCs and 40 series BFG-kdw's this spring on my 1988 IROC convertible.
The combination feels good, handles great but the car (especially the rear) still doesn't sit EXACTLY right.
It still needs to come down another 1/2 to 3/4" to be perfect.
Is there a simple way to get the ride height dialled-in without replacing everything and going to a weight jack setup?
I have also ordrered a new ZZ4 which will be mated to a T-5, to replace my 305 auto combination...any ideas what this will do to the ride height?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Just cut the springs, start small and keep going until you get where you want. Thats the only "real" way to fine tune them.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
http://www.ground-control.com/?D=72f...7607aca9045a31
Groud-Control sells adjustable ride height kits...
Car: check
Engine: check
Transmission: check
I like to use the AFCO Racing adjustable spring spacers. These combined with their springs (or another manufactuer such as Landrum) make for a nice setup. Price is decent too.
www.afcoracing.com
The spacer fits on top of the spring and seats into the upper spring seat of the frame/k-member.
Onthe spacer there is a threaded plate that is rotated in order to set the ride height.
RBob.
www.afcoracing.com
RBob.
Engine: ZZ4 TPI
Thanks for the help guys, I will be in touch with Afco and Ground Control on Monday.
