Rear Swaybar Size on a 1990 IROC?
I am trying to find out the size of the rear swaybar on a 1990 IROC. It appears that the rear bars are interchangeable between the 3rd gen and the 4th gen and I am looking for a bigger rear.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The rears are indeed interchangable, but you need to read this:
https://www.thirdgen.org/techbb2/sho...threadid=59687
The only way to be sure of what you have is to get under the car and measure it where the bushings ride.
Ed
Ed
Thanks for the link. It appears that a 90 would be a 21mm RPO FE2) or 24mm (no code).
The bushings/bushing mounts can slide so that shouldn't be an issue...
I guess I'm in. Thanks.
toronto formula
11-10-2015 06:17 AM
mustangman65_79
08-11-2015 03:17 PM
knight72
08-10-2015 09:32 PM
