Brake line flaring
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
Brake line flaring
I'm replacing all the brake lines on my GTA. I noticed that all the original lines are bubble flared instead of a standard double flare. The problem is, a local shop rents out a tool for double flaring, but not a bubble flare tool.
Does it matter if I replace the lines with a standard double flare? Will this cause me any problems?
Transmission: 5 spd
The guy at my local shop said bubble flare tools are ridiculously expensive... that true?
Transmission: 5 spd
Ok, never mind what I said in the last post... I just called another local shop that I deal with quite a bit, and he said he'd flare them for me, or even lend me the tool, which means I should be ok... as long as I can find all the correct fittings and line!
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The fittings will all be metric thread, and should be a blue color instead of the common brass color. You could probably splice together all the lines using off-the-shelf parts from CTC. The only difference is that some of the fittings on the master and prop valve use different size and thread pitch on the inverted nuts.
Car: 1986 Firebird
Engine: 2.8 V6
You can check online, too. http://www.eastwoodco.com has an ISO flare tool for sale, I think it's $60. I think http://www.toolparadise.com has one, but I'm not sure of the credibility of that website- anyone know?
Oooh- yes, they do, (I just searched the website), and it's even made by OTC! Go to http://www.toolparadise.com and put in "OTC4504" into the search box... they want $20.
Transmission: 5 spd
But thanks for the info guys.... I really appreciate it... I've never been much of a mechanic, but between fiddling around with my car and reading the forums every day at my lunch break at work, I'm certainly learning a lot... and everyone on here is usually pretty helpful.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
in the future for anyone else reading this thread who doesnt have a shop friend that owns the tool:
most aftermarket parts are pipe thread with standard flare adapters... like like locks and prop valves.
you can buy a piece of bubble flare line, and cut off one end.. slide a tube nut on, and double flare it.
