Hotchkis or spahn?
1 Post
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Hotchkis or spahn?
I 'm getting ready to rebuild my suspension and can't decide between Hotchkis or spahn trailing arms and panhard.Any suggestions?
Spohn. They are a site sponsor as ShiftyCapone says, and let's remember that without good sponsors, a site like this would struggle to survive. The products are a great quality, nice clean welds, good powder coated finish and superb customer service. I haven't heard anything bad about Hotchkis though, but I'd go for Spohn if I were you.
1 Post
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Hotchkis also makes great stuff but IMO, you can't beat spohn. Steve spohn makes some great items and he is very pleasant guy to talk to. Just call him up and tell him your goals and Steve will be more than happy to suggest to you what you would need without trying to dive into your wallet. His welds are excellent, he doesn't over price his products, and just about everything you get from him gets a powder coat. Spohn's service and products rock.
1 Post
Car: 00 Camaro SS
Engine: 5.7
Now, should I get the adjustables or stay with the non adjustables?I'm not looking for a super custom suspension setup,just to make the car handle like it's on rails.
Car: 1990 Formula
Axle/Gears: 3:73 Posi
I recently put on Spohn's lca's and panhard bar and if i were to do it all over again i would do the same I also got his subframe connectors but haven't had them installed as of yet.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you plan on lowering, an adj. PHB would be a good choice. heck it is a pretty good choice for even stock car, centering the rear is a good thing to do. IMHO the only reason to get adjustable LCA's, if to get the spherical bearing option. An adj. torque arm is another good part, it allows you to properly set your pinion angle.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
2 questions:
- What's a spherical bearing option? And how does it require adjustable LCA's
- I know what torque arm is and I know what pinion is, but what pinion angle are you guys talking about?
I am planning to redo my entire suspension, and right now looking at different aspects/angles/factors that I need to keep in mind. Looks like I haven't come across these two yet.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Originally posted by ShiftyCapone
Pinion angle is the angle which your rear end is in relation to your tranny. Your tranny, driveshaft and rear end are all not 180* in a straight line. The rear is usually set a little bit at an upward angle so that when it is loaded (car accelerating) it will be at 180*. You can change this setting with adjustble peices (LCA's and torque arm). Depending on your final set-up along with how mich poer you make determines what angle you need. A stock set-up only nees a few negative degrees if I recall.
The LCA's have no effect on pinion angle. The torque arm takes care of it. For the street no more than about -1° of pinion is good. For drag racing on the track you can go to -4 or so depending on what kind of power you car is making.
Car: Yes...
2 questions:
2 questions:
However, it will also create a harsher ride since the rod end can't absorb road vibration like a bushing. They also don't last as long as a bushing and need to be replaced periodically. An adjustable LCA isn't required, but it's the natural result since the rod ends have threaded shafts so they can be replaced easily.
Here's an example of a rod end:
http://www.fkrodends.com/ExtraStrength/rsmxrsmxt.html
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by BretD 88GTA
Actually, the rear end is usually set at a downward angle. Under acceleration the driveline rotates upward toward the bottom of the car.
The LCA's have no effect on pinion angle. The torque takes care of it. For the street no more than about -1° of pinion is good. For drag racing on track you go to -4 or so depending on what kind of ower you car is making.
tnx guys, that clarifies things somewhat.
I still can't picture where the upward force is coming from when you accelerate. torque arm pushing against the rear differential in the opposite direction of rotation?
A picture here would be most cool
So if you want to adjust pinion angle, adjustable LCA's and torque arm are a must, or is torque arm by itself is enough?
1 Post
The torque arm itself is enough. You need a adjustable torque arm if your going to be adjusting the LCA's to set the pinion angle back.
84 TA NV
09-06-2015 08:02 PM
