Power steering fluid flush
Old 06-13-2004 | 01:58 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Guys, please help me out here. What's the best way to flush out the power steering system so i can refill it with fresh fluid?
And what fluid do you guys recommend?
Thanks!! Sorry of this question is too n00b.
Old 06-13-2004 | 02:21 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Get a pump syphon and syphon out the reservoir. Then pour the new fluid in. Drain again if you want and put new fluid in.
Old 06-13-2004 | 03:26 AM
91Z28-350's Avatar
Get some hose, pull the return line and run it to a bucket. Fill up the reservoir, turn on the engine, and then turn it off. Fill, turn on, and turn off. Repeat until the fluid runs clear, then top off, bleed, and top off again.
Vintageracer
01-10-2020 06:33 PM
colton_carlson
03-08-2019 01:21 PM
evilstuie
04-14-2016 09:52 PM
backtothe80s
09-05-2015 01:39 AM
z28_AJ
08-27-2015 09:59 PM
Quick Reply: Power steering fluid flush
