If i dont replace the MC with rear drum/disc swap, will my brakes suck?
Car: 1989 RS Camaro
Are my brakes going to suck now if i dont get a new master cylinder when swapping from rear drums to a 1LE rear disc 9 Bolt?
Car: 4
Engine: 6
Transmission: 5
If you're putting in the PBR calipers (finned aluminum, not the cast-iron ones) then the correct MC for that system is the same one as the drum one anyway.
If you're putting in the cast-iron calipers, where one is in front of the wheel and one is behind, then you WILL need a different MC; the hydraulic requirements (volume and pressure) of that system are considerably different from drums.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Trans Am
Car: 1987 Trans Am
Originally posted by 84 1LE
This is actually correct.The MC is the same for the Rr.drums/ Rr.PBR brakes.The OLD cast iron Rr. calipers use a different MC.The Prop valve is different for each of the 3 types of Rr.brakes.Plus the 1LE set has its own prop valve,but still uses the same MC as the drum/PBR(Rr disc only)brakes.
Originally posted by LT1guy
I'm not disagreeing with what you're saying...you are correct in as far as what the cars came with new. I'm just saying that in my experience, on a particular car that I have worked on and driven, that the MC change wasn't necessary. Honestly, it stops better than my 97 SS, which surprised me with all the horror stories you hear about early rear calipers.
Car: 4
Engine: 6
Transmission: 5
Exactly; what "works" and what's "right" are sometimes 2 different things.
And, sometimes you can do things that "work" fine seemingly, but never even realize how much better it might be if you did it "right".
Frankly, brakes aren't one of those areas in a car where I'm willing to go with what "works", if I know there's something else that's "right". But that's just me. I'm funny that way; today just isn't a good day to die, for me, and not a good day to kill somebody else, either. Don't think tomorrow will be abetter day for either of those things, or the day after, or the day after that, for a long time to come I hope.
1 Post
Car: 83 Z28
Engine: 400sb
i didnt swap my MC or prop valve and my brakes work fine and i have the old junk calipers to boot (lifetime warranty from autozone) i would love to get the pbrs but i cant find cores and the parts places want a huge core charge
Car: 1987 Trans Am
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Drum and Al rear disc cars got the same mc with a 15/16" bore. Iron rear discs got a different one with a 1" bore. Both will work and both will work right, it'll just have a different pedal feel. I've heard that GM actually switched some 1" bore MCs to the drum one when customers complained the brakes required too much pedal pressure.
Car: 1989 RS Camaro
Alright, thanks everyone for the info. Im just going to get a Wilwood Prop. valve. Thanks for all the usefull info
Car: 1982 Z28
I beg to differ on that one...I swapped Redraif's car (87 Firebird V6) to rear discs, using an 84 3.73 disc rear (with the recall kit installed in the calipers), and left the original master cylinder. We did change the prop valve to the 1LE piece, though. I was sceptical as to whether it would work properly with the drum brake MC, but the car stops great, with no issues. Worst case, try it...if it doesn't stop properly, locks up, etc, change to the disc MC.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
I swapped from drums to J65 rear discs, swapped prop valve to the J65 disc valve, it stopped great. Later that year when I took it for NJ inspections, it failed their brake dyno test bigtime...fronts were great, rears were way low on braking force even tho my pedal was nice 'n firm.
I swapped master cyls to the correct J65 part#, re-bled, and went back to the inspection station...passed the brake dyno easily. Stopping power was even better than before also.
So...if you're only measuring braking by your butt-dyno, you may be missing data.
Car: 1987 Trans Am
Originally posted by kevinc
I beg to differ with your differing.
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: 1982 Z28
Did you possibly have some air trapped in the rear lines? I've driven enough F-bodies to know when one is stopping as it should, and this one does. Redraif only knows stop and WFO, with no in between, so the fact that she hasn't hit anything tells me that the brakes are right
. We don't have state inspections here, and I have never even seen a brake dyno, but the drastically reduced braking distance and much better feel over the drum setup is all the proof I need. Maybe I'll do a scientific test between both MCs next time I have it off, but I doubt it could be any better than it is right now.
Car: Turbo Buick
Engine: 3.8 V6
i just set up 11" rotors with basically the same calipers in the back as I have in the front on my nine inch rear. I dont have any brake dyno data but the car stops incredibly well and on the jack stands i had no problem stalling out the motor hitting the brake pedal.
I formerly had the drum brakes in the back and thats the only thing i changed, left the prop valve and MC alone.
Car stops great.
Car stops great.
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
The J50 also became the standard replacement MC. This is what the dealer would/will install and this is what the auto parts stores carry.
My disc/disc (iron rear calipers) 1988 GTA had a J50 MC. It either came this way from the factory or was installed by a dealer. The brakes worked fine. For my 1LE upgrade I installed a new J50 MC and the correct 1LE prop. valve.
The only real difference betwen the the J65 and J50 was pedal feel. The prop. valve has a far greater impact on how the barkes perform.
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
