Help!! stripped lug nut
Old 04-28-2004, 06:05 PM
TGO - 10 Year Member
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I stripped my lug nut really bad. I've so far tried:
1-torquing the other lug nut all the way
2- smaller socket
3-stripped bolt remover (this one made it worse)
What's next ? Should I remove the spindle then punch out the wheel sutd?
any advice???? thanks in advance
Old 04-28-2004, 06:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your pic doesn't work. If you can't get the lug nut off, you can't press the stud out. If you have to, you can drill out the center of the stud until the nut falls off, and then press out the remnant of the stud and replace it.
Old 04-28-2004, 06:58 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You can buy a nut cracker. It looks kinda like a vice. Itll split th nut and it will just fall off.
Old 04-28-2004, 07:13 PM
25THRSS's Avatar
drill it out
Old 04-28-2004, 07:24 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
had the same thing happen, I tried chiselling it out for 2 straight hours. I ended up getting a 12 pt socket and hammering it onto it and jumping on my breaker bar.
Old 04-28-2004, 07:28 PM
25THRSS's Avatar
lol, don't you love last resorts. I had to drill out as much as I could, which wasn't much because the studs are hard sobs! Then I twisted up and down for a few minutes until it finally broke off.
Old 04-28-2004, 07:49 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
what's the nut cracker?? do you have a pic of it? who sells it??
Old 04-28-2004, 07:54 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I tried to use 12 pt socket but I stripped it more. I think this lug nut was torqued over than 200lbs. BTW are you guys able to see the pic?
Old 04-28-2004, 08:17 PM
pasky's Avatar
Mine was a bit worse, had it chiseled pretty badly. Im pretty sure you can still get a 12 pt on that, but if you can get a hold of the "nut cracker" the guy mentioned above, im sure that would be your best bet.
Old 04-28-2004, 10:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use a cobalt bit and lots of cutting oil and it'll go through the hardened studs like butter.
Old 04-28-2004, 10:32 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
my uncle just had this problem on his car the other day we used a punch and kept driving it on the left side until it broke loose a little then grabbed it with a pair of vise grips and removed it maybe we just got lucky .....
Old 04-29-2004, 10:42 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I saw this nut cracker on eBay but .
it will not fit in my IROC wheel but hey I got an idea, I can bust the nut with an impact hammer.
Old 04-29-2004, 10:49 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you have access to a welder, you could weld a socket onto the nut.
Old 04-29-2004, 10:52 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I have welder and I was thinking of welding a hex nut on my lug nut but I afraid to screw up my wheel
Old 04-29-2004, 11:43 AM
THEGENERAL's Avatar
if you use a welder on it man make sure you have some thin sheet metal to put around the wheel or you will get splatter on it ...and that would suck bad
Old 04-29-2004, 05:54 PM
laiky's Avatar
i normally use an airchisel which has never failed me. before using the airchisel i would use a tapered socket from snap-on.
i think welding would work well. i would make a hole in a towel and tape it around the lug then wet it. weld the center of the nut.
Old 04-29-2004, 10:56 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Hell at least you didn't stip out the key to your Gorilla locks like my buddy did. Unfortunaly he had all of the lock nuts. Meaning all 20 nuts were locks.
Stipped out the key w/ about 4 left to go. We had to bleed the brakes after a motor/tranny swap in a 97 Z. Needless to say there is only one key for every set of those locks supposively. Well after more than a few hours, a bunch of JB weld that didn't work... a few beers and a couple Jack and Cokes... I came up w/ this plan to take apart a Gator Grip, use the little pins inside a 22mm socket taped in the correct positions, hammer it on... and then blast that thing off w/ the impact...
Never thought it would actually work!!! :lala:
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
mcfastestZ28
10-05-2015 07:12 AM
gord327
09-29-2015 10:18 PM
3.8TransAM
09-27-2015 08:37 PM
fasteddi
09-10-2015 09:32 AM
Quick Reply: Help!! stripped lug nut
