i want 255's instead of 245's
Car: 91 Z/28 convertible
i have a 91 z28 convertible 305 with the stock 16 inch rims with 245/50/16 and was thinking about putting on 255's will they fit right without rubbing and what size 255's (255/XX/16) would i have to get to keep the same height?
The 255/50/16 will rub very little but only when you
turn full lock.I have 255/50/16 on my 92 Z28.They will
fit in the rear fine.I'd say go for it.
:rockon:
:rockon:
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
yep...
255's in the back look good.
Front: leave the 245's. It'll look meaner, a bulge in the front looks kinda dopey IMO.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Viprklr
Too keep the same height I believe you would need 255/45/16.
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
I just got new tires on the rear, 255/50R16s, they fit/work great, don't think I'd ever put them on the front.
Car: 2002 Formula Firebird
Transmission: 4l60e
I have 255/50/16 kuhmo ecsta 712's all around. My rub pretty bad at full lock. I think my main problem is that my car was originally made with 15'' wheels. I hear the bump stops are different on mine than 16'' wheel cars.
I would stay 245/50/16...they look better. Mine have alittle more sidewall than I would like.
I may get some 245/45/16s once the car is lowered.
Transmission: 4l60e
Really?
They would be alittle lower profile than a 245/50 but I didn't think there would be any problems with them fitting.
