Master Cylinder Capacity
Ok, I have a couple questions. First what is the fluid capacity of a stock master cylinder? Second do you think a high capacity master cyclinder is in order considering the addition of wilwood GN III 6 piston calipers on the front and wilwoods 4 piston calipers on the rear? If a high capacity master cylinder is requireed are there any recomendations? (ie single cylinder, tandum cylinders, dual cylinders. Part numbers would also be useful) Thanks everyone.
Jim
Jim
