Largest Rear Tires on stock 15x7 rims
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
I want 275/50/r15 but someone told me i need more backspacing...what does that mean
I had 295/50/R15's on 15x7 firebird rims a few years back. I put 1/8" or 1/4" spacers in and pounded the inner wheel well in as much as I could. They still rubbed on the inside on real hard turns.
R
R
1 Post
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i just posted about this like 5 min ago in another topic. DO NOT put a 295 on a stock 15. there is way too much sidewall flex and will dismount the tires around cornors. on a stocker wheel, dont go over 255. ive been in the tires/suspension/chassy business for 5 years and have seen a lot of bad things happen when people do things like this...
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i've had a set of 245/60/r15 goodyears on the stock 15x7 wheels.
i wouldn't go any bigger than a 245. that's just my personal preference, though.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Wow... Putting 295's on a 7" wide wheel is brave... No more than 245 (235 is probably a better size)...
1 Post
Car: '89 RS Convertible
Engine: 355
Originally posted by WS6 Berlinetta
I had 295/50/R15's on 15x7 firebird rims a few years back. I put 1/8" or 1/4" spacers in and pounded the inner wheel well in as much as I could. They still rubbed on the inside on rea l hard turns.
R
R
Car: 84 Trans Am
i have the 235's now i think im gonna ger 255's or 245's......in the jegs mag. it says 275/50/r15's drag radials can fit on the 15x7 rims..
Drag radials
Size: P275 / 50 R15
Rim: 7-11''
Tread: 10.0''
Section: 11.3''
Diameter: 26.1''
radial t/a's
Rim: 7.0 - 8.5
Section Width on Measuring Rim Width: 9.8 on 7.0
Diameter: 26.6
radial t/a's
Rim: 7.0 - 9.0
Section Width on Measuring Rim Width: 10.2 on 7.5
Diameter: 27.1
is 27.1 too tall..will me speedo be off by a lot..will my car ride ok?
Drag radials
Size: P275 / 50 R15
Rim: 7-11''
Tread: 10.0''
Section: 11.3''
Diameter: 26.1''
radial t/a's
Rim: 7.0 - 8.5
Diameter: 26.6
radial t/a's
Rim: 7.0 - 9.0
Diameter: 27.1
Originally posted by 84H.O.Trans Am
radial t/a's
Rim: 7.0 - 9.0
Diameter: 27.1
radial t/a's
Rim: 7.0 - 9.0
Diameter: 27.1
I'd also like to state that you shouldn't go larger than that. I've seen several other 3rd gens with 275/60r15 and one with 295/50r15 on the rear. It looked horrible! The 295's were all cut up from hitting the rolled quarter panel. Very unsafe. You could see the tire moving around when he cornered at even slow speeds! The tire just kind of rolled over...
1 Post
Car: 86 Camaro
i use a 295 on the rear but i have a lift so it doesnt rub
and to whoever said they are going to use a 275 on the front... lol keep dreaming
Originally posted by Deemax
That wasn't wheel rub....that was the sound of your tires hitting the fender well as they popped off the rim 245 is about the max on a 7" wheel...that's still more than 2.5" inches wider than the rim.
R
1 Post
Car: 86 Camaro
hey keep acting smart, i dont care. you playing with your own life doing stupid things like that. i suppose you use 16 inch tires on 16.5 inch wheels too? thats the same thing as mounting a 295 on a 15x7...
1 Post
Car: 86 Camaro
Originally posted by z28crazy
what is the biggest tire that can be put on a 15 x 9.5?
