18x9.5 tires
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
18x9.5 tires
hey guys what tired do you recomend for my 91 RS. I want to order the Vortec Z wheels and they only come in the 9.5 wide rim in the 18's. I think it needs a 5.5 backspacing? I want the widest possible tire in the rear. and the best profile height for handling. also what brands do you recomend for all around perfomance, such as a little grippy, good for handling, and good for high speed.
cheers
blake
cheers
blake
I'm running 275/35/18's on my 18x9.5 Boyds. Just a FYI, Performance Wheel Outlet does not make the 18x9.5 Vortech Z's to fit the fronts of a 3rd gen. So the biggest you can go is 17x8.5 fronts, 18x9.5 rears (at least thats what they told me when I ordered a set of 18x9.5 Vortech Z's). As for tires, all depends on what you want. I wanted the best wet and dry traction, so I got Potenza S-03's. There are a few other tires in the 'top of the line' wet and dry category like the KDW's. Or if you just want good dry traction try the Eagle F1's or KD's.
LiquidBlue
Wheels and Tires
32
12-10-2019 05:06 PM
