emergency hand brake problem
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
Hello,
I just bought a 1983 Camaro z28, it only has 62,000 miles, two previous owners. When you pull up the handle on the E brake, it turns the attachment on the calibers in the rear, but does not engage the piston fully to stop the wheel from turning. My rotors and all the pads have most of their life remaining. Several brake men told me to just replace the calipers(which probably would take care of the problem) I was told by a friend that GM had problems with the mechanism in the rear calipers in referance to the hand brake portion, and even had recalls. I do not want to just arbitraily replace the calipers, they work just fine for stopping the car. Is there a way to modify this system without replacing the calipers to make the mechanism work? I rarely use the hand brake, usually just put it in first gear, but it would be nice to have it, otherwise may just wait till the brakes wear down, and then replace the entire rear brakes with new. Thanks for any help or ideas you could give to me. Dennis
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Pasted from the FAQ section on this site:
Q: Do my rear disc brakes need to be adjusted?
A: A technical service bulletin described this for early-mid '80s rear disk brakes. It seems that the rear disks in these cars would be adjusted by applying the emergency brake. When you pull the emergency brake lever up, the lever turns this little device called an actuator screw. This little screw type device is also on a ratchet, so that pulling the e-brake up, turns the screw. But letting go allows the ratchet part to function and set the pads at that time. So, using the emergency brake is mandatory for maintaining the rear disk setting on early model rear disk units.
But, here's the problem with them. There's a little spring on the actuator screw assembly that allows the pads to back-off from the disk a little bit before the ratchet mechanism is engaged. This must be done, otherwise full brake pressure would be left on the pads when the e-brake is released. Well, that little return spring K-factor was not correctly chosen from the factory, and the result is that the ratchet NEVER functions after the actuator screw gets a little dirty. Hence, the pads simply work their way out all the way when the e-brake is used. Using the e-brake all the time seems to keep the actuator free for a longer period of time, but even with the correct spring weight and screw, the e-brake is required to adjust the parking brake actuator.
The TSB states that cars with a manual tranny are eligible for a free fix as the e-brake is required to park the car, but the auto is not eligible. Why? Only GM knows. However, fixing it yourself should be relatively easy. The rear wheels are removed, and there is a nut on the back side of the brake caliper that holds the parking brake lever. Remove the nut, lever, and soft grommets. Put a large washer over the shaft to act as a spacer, and then put a wrench on the hex of the shaft, and tie it down with the nut. Turn the wrench to back the brakes off. After a while, this will over travel, as if there was a one way clutch. Tighten the shaft to see where the hex is when the pads are tight agains the rotor. If it is in a spot that the parking brake lever will fit, and turn about 1/3 of its travel to tighten apply the brake, then it is good. If not, try again.
This will remove some of the brake pedal slop also. It's supposed to be self-adjusting (apply parking brake thirty times), but it is common for it not to work
