Do all 36MM Hollow sway bars have the hole by the end link mounting point in them?
I was looking for a 3rd gen 36mm hollow sway bar in the wrecking yards the other day.
I thought it would help me identify them a lot easier.
I started looking on Ebay and spoted these two.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
Notice the hole by the end link mounting spot.
Now look at this one.
I don't notice a hole in this one.Is this a 36mm hollow bar if it doesn't have the hole?
Yea.. I know, measure the ones that I find with a caliper or a wrench to make sure.
If anyone know for sure???
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
All hollow bars will have those holes, both the 36s and the 34s.
Ed
Ed
Well that was a close one then.
I was going to bid on the black one.
I don't see any hole in the black one.The red one obviously has a hole in it.
The seller sounds like he knows what he is talking about.
Do you think the guy is falsely selling the black bar as a 36mm 1LE bar or could it just be the angle of the picture?
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Originally posted by studdmstr
What kind of performance difference would there really be between a 36mm and a 34mm hollow sway bar?
Car: 91 Z28
Engine: LB9
Transmission: auto
Originally posted by SLP IROC-Z
same stiffness, just the 34 solid weighs a lot more then the 36 hollow. go with the 36 hollow
Car: 1999 Z28
same stiffness = same performance
the only downside is the 34MM weighs more
so when it comes right down to it, the 36 is the better bar
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Do all 36MM Hollow sway bars have the hole by the end link mounting point in them?
All 36mm GM bars are hollow ....to the best of my knowledge.
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
34mm solid has approx same stiffness as 36mm hollow. 34mm hollow is softest of the three.
I alternate between a 36mm hollow and a 34mm hollow ( both modified to be adjustable ) depending on event. Autocross I usually use the 34mm hollow. Hillclimbs and Road Racing ( higher speeds ) call for car to be less nervous...so I use the 36mm hollow.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
