outhandle a vette
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
outhandle a vette
Is is possible, using all aftermarket parts, to make our cars handle better thn a vette or other high end sports cars? I am gonna install all spohn parts, and lower my car. I know this will help, but how will it compare to the others? My goal is to make my car, outhandle a porsche, go faster thana ferrari, for less then a vette. I know this is probably impossible to do, but I'm only 22 and this car is going to be a lifetime project.
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
sounds like you and i have the same goals. around here, we have a bunch of little punks that mommy and daddy bought them new porsches', vettes', and a kid in hilliard got a 04 viper gts for his 16th birthday. they always try to rub it in, so i figure, "woops, you have a $100,000 car and you gave me the privilage of handing you your a$$ today. thank you for making me feel good about myself." bunch of spoiled brats. nothing i would love to see more than a 89 rs kick a 04 viper gts in the nuts. hahahahahaha..
i'm done
thanks, pat
i'm done
thanks, pat
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well you are going to have to make your car handle 1g or more on the skidpad with srteet tires. That isn't to hard but is pretty much the max that any street tire car can do. But overall saolom and body dynamics goes to them hand downs reguardless of what you do. There is a reason why they don't have a strut set-up with a solid rear end. Also, if you want to be in the same leage you are going to have to be able to brake from monsterous speeds in ver very short distances repetitively. I am not talking LS1, or 1LE bakes either. Those won't cut it.
Car: 1982 Z28
Re: outhandle a vette
Car: 91 Camaro RS
Engine: 305 TBI
Thank you Kevin for your input, very helpful. I guess how long it takes, will depend on how good of a job i will get when i graduate.
As far as the cornering and the tires, I plan on getting OEM Z06 wheels. I know they are suppose to be lighter. I'm not sure what the best street tire you can get with those is, but I'll get those too. They normally come with the goodyear F1 eagle, correct? I think i remember an article in a magazine, where they tested a couple of C5 vettes, and changed nothing but the tires. And when they put the Z06 tires on the coupe, it performed just as well as the Z06. So we'll see. That won't be for a little while
Shifty, I do plan on getting good brakes. Once I am finished with all the suspension, I am gonna get a moser rear end. Hopefully, at the same time, I'll get the Pro-Series Spohn has for the front, along with the Wilwood rear kit AGood 2.8 posted a while ago.
I'm trying to build my car from the ground up. The engine will be the last mod I start (actually interior will, but that doesnt count) I plan on installing an LS1 and adding a turbo setup to it. Of course if it takes as long as kevin suggest, maybe I'll use an LS2, or hell maybe an LS3, or an LS4. Maybe those will be designed by then.
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
U in westlake "aftermidnight"? I'm in North Olmsted and I know what you mean. I know a kid that lives in westlake and his dady is the VP of energizer battery. The bastard got a brand new vette for his 16th birthday.....Not Fair...
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I don't know if your car will ever be as good around a track like a Z06 would be but you can get pretty close. The IRS systems they have on cars now adays just blows the 3rd gen out of the water. Don't get me wrong, you will love the way your car handles when you are all said and done and it will scare you. The problem with our cars is that we are only playing catch up by changing to better peices, while the euro cars and vettes have elelctronic shocks and stability stuff that aid them. I have the Goodyear Eagle F1's on my car and they are awesome. Their dry grip is amazing for 3rd gens and cars that aren't so heavy. They don't fare as well on the heavier 4th gens.
Car: 91 Camaro RS
Engine: 305 TBI
Thats what my main concern was. I figured the live axle would be the main problem. An IRS would be awesome, and I have seen a few people who have done the conversion. But I think i'll stay with what we have, and just mod it the best I can.
Another problem we have is wieght. I'm not sure of the weight of the vette, but they are all quite a bit lighter then our cars, correct? And i'm just not sure there is much we can do to get our cars within the same weight as other sports car, and keep it comfortable.
Car: 91 Camaro RS
Engine: 305 TBI
Hey Shifty, handling and braking seems to be your expertise around here. What kind of set up are you running? Have you tried anything different, or unique, with your car, or have you just gone the aftermarket way like most of us?
Ok, i just checked out your site. You have some nice mods. The accident sucks though. When did it happen, and how are the repairs going?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1992
Engine: 350TPI
i'm done
thanks, pat
i'm done
thanks, pat
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Re: Re: outhandle a vette
Originally posted by kevinc
That's about how long it will take...
You throw all kinds of $$$ at a crusty third gen, and yeah, you will "out handle" a Ferrari/Porsche/Viper driven by a yuppie momma's boy, but if you run into somebody who can drive, it will be a whole 'nuther story.
The closest I have come to driving an "exotic" is a an E36 M3 with about the same mods suspension wise on my Firebird. The handling made my Firebird look 100% like the crusty F Body it is. I drove the M3 on two autocross runs and spun the car ech time because turn-in was so quick. Really weird being able to feel a front wheel lifting off the ground.
Pat
Outhandle a Vette in a thirdgen? No problem- especially dollar for dollar. I own a Vette, Matter of fact there are four of them in the family. Average weight of a Vette is not 2700-2900lbs, they are much heavier(even with the fiberglass body) more like 3200-3400. SOme of the older ones exceeded 3650lbs.
You want to handle with the big boys- I know someone that can make it happen. Its not just what you bolt onto the car, its how you set it. Solid axles work very well- ever seen a latemodel NASCAR rearend?- solid axle.
Here's a shot of AGood2.8 making his rounds on Calif Speedway- I video taped him.
More pictures here,
http://www.cardomain.com/memberpage/518752/1
Derek
More pictures here,
Derek
Wouldn't know how to do that. I don't know if I even have the capability with the camera I have. Those pictures where just shot off the TV screen, you probably noticed the lines across the image. I snapped them and e-mailed them to Dean- primitive, I know, but hey it worked.
Car: 91 Camaro RS
Engine: 305 TBI
Hey halfpint, you talk about handling withthe big boys. What exactly do you need to do? I really wanna make my car a great handling one. and while I may not be able to afford to do it all anytime soon, but I would like to learn what I can do to it eventually. You also say yuo know someone who can make it happen, who would that be?
Car: Trans Am
Engine: 455
Transmission: TH350
Weight isn't much of a factor for handling. I can pull 1.2 G's in my 4000 lb 1995 Mercury Cougar. With "only" 17" wheels, good tires, Bilstein Shocks, Addco swaybars, and H&R springs. I have also outhandled Vettes and some exotics in that car(Autocrossed the car a couple years ago). The only good thing the Cougar has going for it over my TA is the IRS rear-end, but my TA handled better than the Cougar stock for stock, so I don't see how it would be that difficult to make one outhandle a Vette. Just go with a good spring and shock, and some good swaybars, and make sure everything's tight with some new poly bushings.
Derek
Car: 91 Camaro RS
Engine: 305 TBI
Yea, he definitely knows his stuff. I enjoyed reading his post, until he was banned. I bet riding in his car was fun, and thats exactly how I wanna feel when i drive my car. And I look forward to the day when I can say I was scared by the amount of speed I carried into a corner.
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The only way you could pull 1.2g's in a 4000# Mercury Cougar is to hit a curb. go back to school and pay attention better in physics class before you post that nosense. A built production 2004 Vette (NON-tubular racing frame car, as in factory framed car) can barely pull those number on racing rubber- FULLY modified.
Suspension geometry design and weight of a Mercury cougar could never keep the tire traction contact patch on all four corners to pull over a even 1.0g's on racing tires never the less 1.2, I don't care how wide the tires are.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Originally posted by Air_Adam
Oh really? So why can a 1800lb Lotus Elise pull 1g with a suspension even more street-friendly and cushy than ours? They have swaybars the size of pencils too.
now, weight does count for alot, but it is not the reason the lotus can outhandle thirdgens. there are quite a few very heavy cars that handle very well, heck look at the OTHER lotus cars, the Esprits are now weighting in at over 3000lbs, and no one would consider them anything short of a true supercar, they are just as capable. the credit for these cars isn't their weight, it goes to show how good the lotus engineers are at what they do.
