Pressing front control arm bushings & ball joints
Car: 1989 GTA
Engine: 5.7L
For the guys who have pressed in their own ball joints and lower control arm bushings, was it enough of a PITA that if you had to do it over again you'd have a shop press them?
I've thought about using a ball joint press to do the bushings and the ball joints, but have heard a few nightmare stories about getting the things to go in straight. Seems like the going rate for a shop to do these is $15 a bushing/joint, which works out to $90. How much trouble is it to do it yourself?
I've done it a few times. A ball joint press costs about $100, or you can rent one for free from autozone. I bought one just because it feels damn nice to have one laying around, you can also press control arm bushings and u-joints with them.
The trick i've found is to not even bother trying to run the press by hand. Just grab a 1/2" impact gun, put an impact deepwell socket on it (13/16 i believe...) and just crank on the press for a second or two. VERY IMPORTANT: then get a hammer and hit the press screw, then hit it more with the impact gun, repeat until it's off.
You could do it by hand, but it's a pain, just be sure to drive the screw in with a hammer every now and then, it's probably the most key thing to do.
I've also known a few people who would just slam the old ball joint out with a hammer, and then use a piece of wood to hammer the new one in so they dont damage it.
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Pressing front control arm bushings & ball joints
I have a small, hand ball joint press and attempted to use it to remove the bushings. It couldn't budge them and all I did was waste time.
Car: 1989 GTA
Engine: 5.7L
Yeah, the key is to lubricate the threads. I use an otc press and i've never had a problem with it. The snap on press costs about $400, and the otc one about $100.
1992rs/ss
05-19-2020 07:02 PM
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
NBrehm
08-05-2015 07:57 PM
