69 Camaro Z28 RS
Car: 95 Trans Am
69 Camaro Z28 RS
My stepdad wants to put different tires on his 69 Camaro Z28 RS with the 302. He wants to put 245/60/15's in the rear and 235/60/15's in the front. He wants to know if they fit and also, if they do, would they fill up the entire wheel well or would there be a lot of wide open space between the tires and the body. If those don't fit then what size would fit and fill up the wheel well. Any help here would be appreciated. Thanks.
Car: 4
Engine: 6
Transmission: 5
IIRC the stock wheels were 14". So he'd need aftermarket wheels.
They'll fit fine, especially if he uses 7" wheels in front and 8" in the rear, with those tire sizes. Lots of people have been using those sizes just like that for years and years.
Make sure he stores his OE 14" Camaro "rally" wheels, so he can restore the car to originality at will, if he still has them; and especially if he still has the center caps and trim rings (the full set).
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
16" WHEELS, WILL THEY FIT?
16X8 WILL FIT FRONT AND REAR WITH 255 50 16" TIRES TOO :lala:
I KNOW I RUN THEM ON MY 69 BIRD ALL THE TIME
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Stock on the Z28 i think was 15x6 Rally wheels... i dont think there were 14s on the Z28.
try www.1stgen.org
CarGuyDennis
137
12-06-2016 11:02 PM
GVMV
08-16-2015 08:01 PM
