Does your Spohn Adjustable Panhard rod rattle?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well the rear end has rattled ever since I lowered it over a year ago. I thought it was the springs but today I dissmissed that theory. I pulled the rear springs and put a piee of nylon reinforced rubber tubing around the top coil and put them back in. Low and behold, the rattle remained. SO I investigated more and foud the sound to be coming from my Spohn Panhard rod. Not on the adjustbale side but instead on the other side. I tried to get a picture but my camera was being stupid and would not take a clear shot. I have the basic adjustable one and not the double eneded or spherical rodded one. Does anyones else rattle here?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
which design do you have. it is very important the jam nuts are TIGHT. if they are loose at all it will rattle, and you risk breaking the peice.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I found a pic after all that came out. This is where the rattle is coming from. But the piece is not loose.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
Re: Does your Spohn Adjustable Panhard rod rattle?
if that picture IS your car, try putting the spherical bearing on the axle side, and the other side (if it is poly, if it is spherical also, disregard this) on the body side.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Re: Does your Spohn Adjustable Panhard rod rattle?
is that picture your car?
Car: 1990 Camaro RS
body side is on the pass side.
your picture has the bearing on the body side.
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Is there ANY play in the heim joint itself? The smallish ones like that tend to wear out like PRONTO on a street car.... Just remember that the outer portion of that joint is "smashed" around the inner portion and that metal is not exactly heavy duty. That and the teflon (or whatever) lining of the joint will wear out quite quickly as well. I would try to position the joint itself so that when you tighten it up the heim is centered and not all cocked to one side like that. There are rubber dampeners that you can install with the spacers that will keep it centered and quieter. I have seen people use zip-ties for that function as well.
Not sure if any of that will help your exact rattle problem or not, but those are things to keep in mind when running heim joints.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Hey thanks guys. Looks like I will be switching it around tomm. I will also try to keep that joint centered. It is really hard to adjust these thnings on the car without going to far or making that joint out of allignment. i would hope that this peice isn't worn out yet since it only has a soft 2,500 miles on it. Maybe less.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by Justins86bird
Mine was noisy, then I got a new rod end from Spohn and it quieted up.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Did you just buy the end or a whole new unit?
Car: 1990 Camaro RS
Originally posted by CaysE
Does this affect adjustable panhards with poly on both ends?
which way it is mounted, has no effect, as you have the same bushing on both sides.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well I turned it around this morning and it seemed to work. I also made sure that joint was as centered as possible and not cocked to one side like it is in the pic. I gave the car a good shake and it appears to be gone. Thanks for all your help guys. I would have drove it to make sure but the motor is all apart for the cam swap.
which part? the jam nuts. YES even more so on poly/poly, when the poly binds, it can actualy start to back the jam nut off.
Ever since these adjustable parts came out, my biggest concern has been longevity. Should there be a better design in the way the adjustments are locked in place? I drive my car every day through rough NJ roads, which I'm sure would just end up jarring the adjustment out of wack on my panhard and LCAs (once I get them).
Car: 1990 Camaro RS
as long as the jam nut is tight you will be fine. the panhards shouldn't back off, but if you put the poly into bind, it can work its way loose after a while. i would put some locktite on the lca's jam nuts.
Hotrodboba400
12-10-2019 07:07 PM
TOMcat GTA
09-15-2015 09:31 AM
