Homemade 10 point S.T.B. what do you think.....
Old 11-27-2003 | 01:38 PM
JERRYWHO's Avatar
I love days off you can get some things started. The S.T.B. is all 4130 and the weight is just over 11lbs what do you think.
Jerry
Attached Thumbnails Homemade 10 point S.T.B. what do you think.....-mvc-002f.jpg
Old 11-27-2003 | 03:24 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
That looks pretty sweet....Has it helped out a lot?
Do you have closer pics and/or from different angles?
Old 11-27-2003 | 04:19 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
D@mn son, that looks mean as all hell. How does she feel with it? Looks like a spider in your engine bay....
Old 11-27-2003 | 04:26 PM
25THRSS's Avatar
whoa. Looks good but maybe a little overkill. It would be a bitch to work on things now.
Old 11-27-2003 | 06:05 PM
nolanr0413's Avatar
Car: Trans am
thats cool, i dont know how much it helps but it cant hurt, it looks awesome too.you should have that powdercoated.
Old 11-27-2003 | 07:23 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Congratulations on your home made STB. It looks really good. I only wish I knew how to weld.
Old 11-27-2003 | 09:32 PM
CrazyHawaiian's Avatar
Car: too many ...
Looks like a chassis cage in the front. If you really need that much strength, I say weld those pieces on the side to the body and make them permanent. Then make the removable STB part just connect the strut towers. But thats just how I would do it. Everyone has their own style. Nice!!
Old 11-28-2003 | 01:19 AM
JERRYWHO's Avatar
The STB is not for me (my car in the picture ) its for my kids car and needs to be a bolt in unit. It still needs to be finish welded and power coated before installing it on her car.
Jerry
Attached Thumbnails Homemade 10 point S.T.B. what do you think.....-mvc-003f.jpg
Old 11-28-2003 | 01:20 AM
Kandied91z's Avatar
why 10 points?
Old 11-28-2003 | 01:46 AM
JERRYWHO's Avatar
Originally posted by Kandied91z
why 10 points?
I wanted to tie the firewall and the core suport to the strut mounts and thats what happened. Just trying to get the front end a little stiffer and thats good for a road type car.
Jerry
Old 11-28-2003 | 07:36 AM
_max_'s Avatar
nice job jerry looks real good
Old 11-28-2003 | 07:48 AM
MdFormula350's Avatar
thats freaking awesome!:hail:
Old 11-28-2003 | 12:33 PM
JERRYWHO's Avatar
Finish welded and removed from the jig ( my car ) and test fitted on a all stock 90 Camaro and it clears everything.
Jerry
Attached Thumbnails Homemade 10 point S.T.B. what do you think.....-mvc-005f.jpg
Old 11-28-2003 | 09:02 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
That's no strut tower brace, that's an engine bay brace. Looks totally killer, make me one!!!
Old 11-28-2003 | 09:21 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Damn, a roll cage for a motor!!! Nice work, you got too much time off.
Old 11-28-2003 | 09:54 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
Very nice work.
I was thinking of firing up my welder to build a custom STB myself since I am having trouble finding anything that will clear my Superram. But I definitely did not have anything like your masterpiece in mind.
When are you going to build the rollcage?
Old 11-28-2003 | 11:45 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
thas flat out funny Hg
Old 11-28-2003 | 11:49 PM
SLP-GTA's Avatar
OH I almost forgot
how are you going to pull the engine (if needed) if that 10 point brace is welded in place, food for thought
Old 11-29-2003 | 12:20 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
well if it gets welded in place, he has to drop the crossmember holding the motor, would be really the only way.
Old 11-29-2003 | 12:28 AM
JERRYWHO's Avatar
Re: OH I almost forgot
The brace is a bolt in type, 10 bolts hold it to the car and thats the reason for the flat plates on the ends of all the tubes.
Jerry
Old 11-29-2003 | 12:59 AM
FLYNLOW92rs's Avatar
How much are you selling that thing for?
Old 11-29-2003 | 01:43 AM
CaysE's Avatar
What flynlow said: sign me up!
I'd probably not put it in though... I'm arachnophobic.
Old 11-29-2003 | 07:23 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
How much does it weigh?
Old 11-29-2003 | 09:09 AM
JERRYWHO's Avatar
14 1/4 lbs unpainted all 4130 TIG welded
Jerry
Old 11-29-2003 | 09:12 AM
Dr G's Avatar
Re: Homemade 10 point S.T.B. what do you think.....
Originally posted by JERRYWHO
....The S.T.B. is all 4130 and the weight is just over 11lbs .....Jerry
Edit:- Whilst replying Jerry got their first!
Old 11-29-2003 | 12:39 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Deff... now Only if it would clear a Holly Stealth ram.
Old 12-01-2003 | 11:42 PM
:lala:
Old 12-01-2003 | 11:56 PM
devianb's Avatar
Seems a bit excessive. Id be more than happy with just a 2 or 3 point stb. Lol good work though.
Old 12-02-2003 | 12:03 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Nice!
Old 12-02-2003 | 12:53 AM
JERRYWHO's Avatar
I don't make parts for sale at this time.
Jerry
Old 01-20-2004 | 10:41 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
care to share the diamensions of your design?
Old 01-20-2004 | 11:31 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Is there any true benefit to this?
Old 01-21-2004 | 06:24 PM
UmmaGumma's Avatar
Car: 2007 Infiniti G35 SEDAN
Engine: 306HP 3.5L V6
Transmission: Auto Pilot Baby!!!!
Axle/Gears: Don't care!
Jerry
Do you make them for give-aways?
Old 01-21-2004 | 10:23 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
lmao.
The benifits would be very little flex for the front suspension. Plus, if your ever in a serious front end colision, I could imagine that would really make the front end much safer and stronger.
My goodness thats a work of art. What fathers do for their daughters these days.
I just noticed it looks like he's not going to be able to use the SLP air intake system, because a bar is covering the airbox.
Would you even be able to take the battery out?
Old 01-21-2004 | 11:12 PM
JERRYWHO's Avatar
Sure what do you need. The tubes fit very tight and the only way I can see someone making one is on a car for a jig.
Yes, It is like Lower and upper wonder bars, Toe or tunnel brace, oversize core support cross brace and 10 point subframe connectors. The stiffer the car the better.
Yes, I made super ram runners for TPI and others people have them and custom over the core support cold air intake and other parts if it's a fun project.
Originally posted by TransAm12sec
What fathers do for their son these days.
Daughter.
I used my car for the fab time, Her car has a standard TPI intake for it.
The STB unbolts to get to all the stuff under it.
Jerry
Old 01-21-2004 | 11:57 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
How thick is that center piece of flat? Unless it's 1/4", seems like it would just flex with basically no structure to it and ~7" span.
Pretty cool though, I wish the stuff I fabricate would come out nice and clean looking like that.
Old 01-22-2004 | 01:27 AM
JERRYWHO's Avatar
The center is two parts of .125 thick 4130. So it's 1/4" thick in the center.
Jerry
Old 01-22-2004 | 12:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's what I thought too.
Old 01-22-2004 | 06:12 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Holycrap batman, to the bat-mobile!
Looks pretty strong though!
Old 01-23-2004 | 02:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am not sure how strong that piece is but what happens if the car is in a high speed frontal impact?
I'd be worried that the 2 bars near the firewall would come into the car and injure the passenger and driver.
If the piece is really strong, I'd think that the bolts would rip out of the flat mounting tabs and the whole unit would shift towards the back of the car into the passenger compartment.
Old 01-23-2004 | 03:35 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
That thing looks beastly....awesome job!
Old 12-20-2010 | 11:30 PM
  #42
Stephen's Avatar
Car: 87 GTA
How did you bend that tubing? You have a tubing bender to use? Or did you use a torch to soften the bend area & form it around some wood blocking?
Old 12-21-2010 | 06:28 AM
  #43
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:43 LSD
agree with teh front end collision concern. Isn't the front end designed to crumple on these cars to absorb energy from an impact?
not ******* on your work at all - I think it looks amazing and given how wobbly third gens are, this looks like it would add awesome rigidity
Old 12-21-2010 | 08:25 AM
  #44
EvilCartman's Avatar
Car: '82 Z28
Holy thread resurrection batman...
Old 12-21-2010 | 10:23 AM
  #45
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes, he has a tube bender.
Old 12-21-2010 | 01:53 PM
  #46
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Lmao
But yes, this must stiffen the front of the car massively, although it looks odd and i can't imagine working on the engine with this in it!
Performance is probably there, but practicality isn't. Cool design nonetheless!
Old 12-21-2010 | 02:04 PM
  #47
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
It doesn't seem like 7 years ago that I first saw this thread!
hectre13
Car Audio
26
03-03-2022 05:38 PM
gixxer92
05-18-2017 11:20 AM
tmellott89
10-14-2015 02:06 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
SRKLEGIN
09-30-2015 07:19 PM
Quick Reply: Homemade 10 point S.T.B. what do you think.....
