Baer bumpsteer kit + Firehawks = no worky
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
here's a pic of the Ronals (17x9.5) with a baer bumpsteer kit installed. I have 1LE brakes so I don't have to run a spacer, but if I install the spacer there is clearance but my wheel sticks past the fenders (too much).
The angle may not show it but even I removed all the spacers and there was still interference (wheel couldn't properly seat). But by removing all the spacers you might as well run a stock moog outter tie rod....but I just wanted to experiment. They fit fine with my IROCs and had plenty of clearance.
Car: Z/28
Engine: 355
Transmission: Turbo 400
Its the rim width and offset. I was wondering the same thing
about the bump steer kit. I run a 16x9-1/2 inch rim and the stock tie rods are so close to the inner rim lip that ocassionaly a rock will get wedged in between the two when I'm driving and put grooves into the inner rim lip. I guess baer missed on that one.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
nows the time to get bigger wheels... you can get rid of thoes worthless ones that dont fit by giving them to me
actually, does anyone have a pic just like his of how close the stock clearance is?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
That sucks. I was thinking about the Bear trackers too. Even the 13" baer brakes dont fit these Firehawks.
Car: 2004 GTO
At least we now know the BAER bumpsteer kit won't work. I was looking into getting that too.
Originally posted by formul8!!
The reason the BAER 2 pistons won't fit is because the sit on top of the rotor with no window at the top. The Brembo, WILWOOD, or Baer 4 pistons will fit because they hug the rotorand have more clearance at the top of the caliper due to the cooling window for the rotors.
Perhaps a list can be made of which rims fit the bumpsteer kit and which dont.
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
So what about the Baer front kit with the 12 inch roters and two piston calipers - will that fit ?? - I have these rims and need better brakes sometime soon.
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
1Aauto
Sponsored Vendors
01-15-2016 06:25 AM
84 TA NV
09-06-2015 08:02 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
