Baer Brakes on. Front moved out, tire rubs wheel well, Can I swap rear's to fronts?
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
These are on Formula rims. I know its suppose to be that way for the tie rod but if its moved out now can i put the backs on the front to move it back in to its orig location?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Why not try and see? The rim offset is 16mm. How much difference did the baer brakes makes? I think it be closer to 1/2" or 12.7mm. You may just bearly be able to get them to clear. If not, you could try a 1/8" or 3mm spacer.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Rubbing on what? Wheelwell or suspension parts? I didn't get that part...
Ed
Ed
AkDrifted
08-17-2015 07:45 PM
