ZR1 wheels.....How can I fit 17x11's out back???
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
These wheels are pretty easy to come by these days for a good price, so I was wondering If there is anyway to fit 11 inches wide in the back without super modifications. I have all the necessary equipment to do pretty much anything, but I don't want to chop the car up too bad.
My dad owns a body shop so I could even widen the fenders if I needed to. I'll be running over 450 horsepower but still want 17's. So I'm gonna need at least 11 inches of rubber back there.
Has anyone done this???with this wheel????
Car: Firebird SSA
Engine: 3.1
17x11 comes in two sizes.
Acutal ZR1 rims in the rear are 36mm offset
Grandsport (ZR1) rims in the rear are 50mm offset.
The acutal ZR1 rim needs to be pushed out 1.25"
The Grand Sport needs to be pushed out 2"
I think you can use a 4-Gen rear end and used the Grand Sport with out any problem. (I think)
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
www.skulte.com will have the adapters for you.
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Can I see a pic of these on someone's car? I just wonder if it sticks out so far that you'd think a hill-billy drives it. Any problems with rubbing?
Visiting Skultes website is a good idea. That guy is a madman when it comes to wheel fitment. He has fit 10.5" wide wheels on the front and 11" wide wheels on the back. You just need the right backspacing and offset, and considering the guy makes his own adapters he's set! He will know how.
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I can't comment on the wheels, but I am running 315/35-17 BFG Drag Radials on the rear of my 92. I didn't need to do anything other than remove the bump stop, which I might have been able to leave alone. I am using 17x10 Weld wheels with 5.5" backspacing if I remember correctly... Its been a few years since I bought the wheels... Hope this is helpful....
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
92 zzz28 can you post a pic of your car with those wheels? I would like to see how they look on your car. I am trying to decide on wheels as well.
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Car: Guess
Engine: Crazy 8
Yeah, but give me couple of weeks, I loaned my camara to a friend for a few weeks...I may be able to find a pic of the car, but with different tires...same wheels though...
Car: 91' RS
Engine: Built 355
hmmmm......
Originally posted by JERRYWHO
I have a brand new in the box pair if you need some 17x11s and the price is right.
Jerry
Jerry
I have ZR-1 wheels on my 95 Trans Am. I need 11 inchers out back. 390 hp to the wheels is shredding 275's. Mine are painted though.
Are those the right offset to fit a 4th gen with no modifications???
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
That would be sick. Maybe someone can photochop a pic so we can drool over it in our dreams.
I am in the process of doing the whole 11" wide rim thing. That pics do you want? i have everything. I will need machine my spacers as I made more room under there than I need right now, so i can tuck them even further. I am also kinda retarted/insane and am trying to pull of 335s. (old Viper tires)
here are a couple pics. They are all on my CD site. just surf around there for a bit.
by the way, I KNOW THEY STICK OUT. That is for all the guys that love to point that out and love to disregard the fact that it is a work in progress.
and one last one that shows a nice shot of them tucked just another 1/4" ( no rotor to see what it would look like)
later
-Dennis
later
-Dennis
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
those are big tires... it looks like yopure building a nice car there, i figured ill stick with 315's so it will be that much easier to get them to tuck correctly.
looks amazing man!
looks amazing man!
Engine: LS3
thx. I too will be going down to 315s, I just got a killer deal on all 4 of the old Viper tires. 200 bucks shipped. I also figure I needed some crappy tires while everything is breaking in.
Thanks for the compliment. The monster should be done in the spring.
Transmission: A4
Re: Re: hmmm........
Would it be safe to mill off a 1/2 to 3/4" of material where the end of the tape is touching in the picture that jerry posted? This would push my 11" wheels just inside the lip and look a lot better.
Engine: LS3
Thats not worth it in any way for 2 reasons:
1. you would be making the wheel weaker in a way it was not designed for.
and
2. You have to get spacers anyways, so just get a thinner spacer and it does the same thing as the machining of the wheel.
You need 2" spacers ususally. You wanna try and have it tuck more, then just get 1.7" or 1.5" and go from there.
and
Transmission: A4
I already have a 4th gen rearend so I do not need spacers. I need to find a way to get the wheel pushed in a bit. The only other way to do this to it get rid of the 4th gen rear and buy new wheels with a custom BS I guess. All well.
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Transmission: A4
They are American Racing racing wheels. 17x11 and 17x9 1/2. The wheels are called Le Mans and they are discontinued. The backspacing on the front is the same as a 4th gen fbody and the rear is the same ZR1 wheel. Thats all I know
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Originally posted by irocdan
are you lowered?
are you lowered?
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
im lowered 1.5 all around by jammex springs.im running 2.25" adapters up front and 1.25" rears with the grandsport offsett.yes i rolled the fender lips and had to massage thr inner fender wells,but its cuz im lowered.if you arent you will have less probs.
Engine: 406 Roller
also, eibach sport kit. - only "mod" I had to do was cut the front and rear corners off the bump stops. It wouldn't rub here other than on a lift w/ tires hanging though, so no big deal...
Car: 88 Iroc vert
yes im sure they will but more massaging of the inner fender wells,plus you will need an adjustable panhard bar to center the rearend so you aren't over too much to 1 side
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Re: ZR1 wheels.....How can I fit 17x11's out back???
i almost *utted when I saw your pic of the 11" on the 4th gen rear, I'm picking up a 4th rear and want to do GS 17x11's in the rear, now I know it will work
