Shocks to solve tire rub???
I recently put 15 x 8.5 wheels with 255x60x15 tires on the rear of my 1988 Camaro coupe, all is fine till I hit a bump or hole at 60mph or more. Then tire rubs on driver's side.
Shocks are about 20,000 miles old. Would changing to a stiffer shock help?? What's a good reasonably ( I'm really hurtin' for money) priced shock?
The cars stance is exactly where I want it now, it just comes down too far on a bump.
ps: I have already shaved out the top lip of the wheelwell.
Car: 90 RS
Engine: LO3
Your shocks don't seem that old but here is what I would recommend. JCWhitney sells a rubber spring helper that you just twist into the spring and it will prevent it from bottoming out on large bumps. It works,, I installed some Suspension Tech lowering spring on my car and I would bottom out on every bump. Once I install these rubber spring helpers things were much improved. So you can spend about $50 on some new KYB rear shocks or 20 dollars on some rubber spring helpers. Of course if your tires are sticking out and you hit a real good bump something has to give and you will still have this problem. Good luck.
Car: 1986 Firebird
Engine: 2.8 V6
Where does it rub? On the wheel lip, or inside the wheel well, near the bottom? I had to "massage" my inner wheel well, near the bottom, with a 15 pound sledge...
Just be sure to buy a new can of undercoating and spray that area after you beat the snot out of it!
I also have the Suspension Techniques springs, and my P245/60r15's on 15x8 rims are looking pretty close to the quarter panel lips. I put on KYB gas-a-just shocks from summit racing, they don't seem to be interfering - yet. You could also try increasing the height of the stock rubber snubber that hangs down from the wheel well (and hits the axle), or, buy a new poly snubber that's longer.
2MNYMaros
09-15-2015 11:36 PM
83 Crossfire TA
09-08-2015 12:06 PM
