Just took my anti-sway bar off
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
I just took off the front sway bar and to my surprise it is hallow. It is just over an inch wide. So does this mean I have the good sway bar?? My rear one is small and crappy. I think someone may have replaced the front one at some point in time for some reason. When I tip it end to end I can hear rust moveing inside of it, is that a good thing??
Hear are a few pics I took of it...
http://192.168.0.3/images/nick/
I'm gonna paint it today too. I'm thinkin red to match the LCA's, and Wonder Bar.
Car: 82 camaro SC
192.168.x.x is a LAN IP address and will never 'travel' across the internet. Hollow 36mm is the good one. You give up some stiffness with the hollow bar(which is why you want the bigger 36mm one) but it is lighter. Measure both accurately. The rear bar should be much smaller than the front. You will want a matched set that work well together--mismatched will get you a loose or tight car.
darwinprice
17
10-11-2015 11:51 PM
