Cold or Hot formed roll bars which is better
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Quoted from manufactures on sway bars, one said
"Made from cold formed steel to better resist torsional fatigue and retain their "memory" far longer than conventional hot formed bars"
the other
"Our bar stock is 4140 chrome moly heat treated spring grade steel. The bars are entirely heat formed and coined as one piece. We put our bars through this extensive process to insure that the final product will be the strongest, most durable bar on the market, and that it will be the most resistant to form alteration. Most aftermarket anti-sway bars are cold-bent, making them weaker at the bends, and more vulnerable to shape alteration"
Also what the standard size of 32mm and 21????
the other
1 Post
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
From what knowledge I have learned about spring rates and metals over the years- my educated guess is that springs that are heat treated will retain there shape and spring tension from that point on more consistently than cold formed springs.
However- take a cold formed spring with 1" solid diameter and a heat formed spring with 1" solid diameter. With all being the same other than bending process- the cold formed bar will be a higher rate but will loose tension a fair amount over time. So the heat formed spring, while loosing some initial spring rate from the heat process- will maintain that finished formed rate much more consistantly over time- it remains more predictable/constant.
My choice is the heat formed metal. As long as it is a matched rate front to rear after the forming process then you cant go wrong.
1 Post
Car: '87 Chev
Engine: 60*V6
Re: Hey autoXs
Originally posted by SLP_GTA
what is your input
what is your input
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: '94 Corvette
32mm = 1 1/4
21mm = 13/16
..or close to it..
I have Spohns set also...Nice - real nice.
1 5/16 front x 1 rear
Dang, if your getting 1.07g, than I can't imagine what mine is going to pull with 11" slicks & no interior weight what so ever.
Ron
21mm = 13/16
..or close to it..
Ron
1 Post
Car: '87 Chev
Engine: 60*V6
Ron [/B]
Ron [/B]
I would go for the heat treated chromoly. Its strength is superior to regular steel, cold-formed or hot-formed. But if chromoly isn't heat treated its not much stronger than mild steel.
rudolphschenker
09-04-2015 02:41 AM
