Hollow Vs. solid sway bars
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
What is the advantage of a hollow sway bar over a solid one or is a solid one better? The hollow 34mm was the best GM had, but why is spohns solid? Or could GM not affort to put solid bars in?
1 Post
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
weight is the biggest issue with the sway bars. Which is the reason GM made them hollow. A 34mm hollow is weaker then a solid 34mm. I believe that the material that spohn uses is alot lighter (chromoly) then the stock material. (possibly steel? iron?)
FYI, GM made the so-called 1LE sway bar, which was a hollow 36 mm. These came on some 89-92 Camaros and some 86-92 Firebirds in conjunction with a solid 24 mm rear. These are available at bone yards and, I believe, can still be had from GM. The front is part # is 14094344, the rear 10035033. I can provide the part numbers for the bushings (a higher durometer rubber) should you need them. I suggest, however, going with the greaseables from Top-Down Solutions or Spohn. Check my sig.
JamesC
JamesC
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Hollow bars have the advantage of being much lighter, and only being slightly weaker. If you look at the stresses and Polar Moment of Inertia of a torsional member, like a swaybar, you will see all of the loadis carried by the outer portion of the member. So the middle or inner part really does nothing but add weight!
Lon Salgren
Top-Down Solutions
darwinprice
17
10-11-2015 11:51 PM
