car sitting unlevel
car sitting unlevel
well before I replaced all my shocks and struts the car sat pretty level and afterwards the back right passanger side sits alot lower than the rest of the car. When I was replacing that shock the jack holding up the axle fell over allowing the rear spring to come pop loose but it did not fall out. So i just put the jack back under the axle and just jacked it back up. and i made sure it didn't happen with the other, but that is the only thing different that happen. if you have any info or question please reply.
Maybe your spring isolator for that tire popped out and is lying around somewhere. I'd say jack it back up, compare the driver and passenger sides, and make sure everything is where it's supposed to be.
the isolater may still be up there. I know on my car, one of them doesnt want to come out, and thats fine with me. BUT if its not seated right in there, your car will be not level Therere is a groove that the end of the spring has to fit into.
