2" wheel adapters for ZR1 wheels?
Car: Camaro
Engine: 350 SBC
Transmission: Five speed
Does anyone use 2" wheel adapters on all four corners for ZR1 style wheels (from camaro SS). If so, how do they fit? I searched this site already and there have been people using so many different sizes, i'm still not sure.
1 Post
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I've got 2" wheel spacers with the SS rims and they fit good. They push it almost all the way out to the fender. If you have a good drop (I have a 3" drop) then your gonna to either roll the fender or cut it. Cause it'll hit it. Or if your gonna be taking the turns hard and the body is gonna roll over it might also roll and hit hte fender. Just a warning.
I also HAD 2" front and rear for mine. Skulte recommends the 2" front and rear for the factory 17x9. If you run the aftermarket 17x9.5, the width may change. With just a minor 1.25" drop I had no problems with rubbing at all. I still have the 2" spacers up front, but because I am now running a 4th gen rear, I have an extra pair just sitting in my garage taking up space
