special tools for control arm bushing install
Car: '84 Z28
Transmission: th2004r
what special tools do you need to put in new control arm bushings?
edit:also, should i replace my ball joints or anything like that in there while i have it apart? how much do ball joints cost? do the ball joints come in the kit for the control arm bushings? i'm probably getting the prothane bushings.
Car: 1992 Z28
You'll also need a hammer. I just replaced my front suspension. Separting the steering knuckle from the a-arm was a pain....had to hammer the prickle fork like no tomorrow. You can get ball joints from AutoZone for $16 with Lifetime warranty. Woundn't hurt to change your end-links while you got everything off. Easy to replace and inexpensive. You can rent all those tools ede mentioned at autozone. Ball-joint press tool being the most expensive ~$99 But of course you get all your money back when you return them.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
