Does this look like a stock 91-92 Spring or aftermarket?
I have a 92 RS parts car, I took the springs out of it, to put into my 83 Z28. The springs look TOTALLY different. I was going to cut one coil off the 92 springs to lower the car a little.. but then I pulled the 83 Z28 springs out and they look very different.
The 92 springs are on the right...
Thanks guys..
Thanks guys..
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
heres a pic (from left to right)of an rs front spring and a iroc front spring and two iroc rear springs. (this is what i just removed from my car)
about your pic i dont think those rs springs look stock,,,,,but I havent acually seen a newer style one and they may be different im not sure. Regarless put those springs on the right in your car right away!!! I know some eibach are black but im not + if those are eibachs springs. Any part numbers on them???
Thanks guys, I put the springs in, and WOAH, talk about low, I have 24" from the top of the wheel arch to the ground, and the tyre is the same height as the fender.. Luckily I didnt assume they were stock springs, and cut a coil of them!
Car: '81 Trans Am
Engine: 6.6L
cool stuf,,,,did you do the rear too,,,you should!!! there even easyer to change. Looks great I think!!!!!!!!
sailtexas186548
08-26-2015 03:32 PM
