Tire pressure gauge, which kind and how do know if your is accurate?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
i seen a tire gauge at auto zone that I was going to buy, and I was wondering how do you know if it is a good one? If a gauge is off a pound or 2 that is going to make a diffreces. thanks
Car: 86 Z28
For my motorcycle it is pretty important to keep the air pressure to a accruate measurement when you are going around curves and over a hundred.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I have 4 different gauges. I've tested them all with other peoples giving me a total of 7 comparisons. My conclusion was reached by seeing which ones had the same readings. Of the 7 only 2 were the same. They both happened to be (different brands) the RV type. has the gauge with a small hose and a pressure release button.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I got one from Longacre racing. It's got a nice rubber shock resistant cover and seems to be very accurite and consistant. I use it for my race tires and I need consistancy above all.
http://www.longacreracing.com/catalo...id=228&catid=8
colton_carlson
03-08-2019 12:21 PM
86IROC112
08-17-2015 02:00 PM
R3500
08-17-2015 12:16 PM
