Global West Del A Lums Within
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Anyone else looking to buy the del a lum front control arm bushings any time soon ? Thunder racing has them for $129 and I figured if we can get some people that are ready to buy right now it may be worth a shot to try em for a group purchase, or anyone else possibly find them for cheaper ?
Car: 93 240SX
Engine: LQ9
well, 2 so far, talking with some others to hopefully increase the number, btw justin, are those model kits in the picture guide you have your own ? if so could you possibly give me the kit numbers from the boxes on a few of them?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Car: 93 240SX
Engine: LQ9
Well up to 3 so far, i figured we'd probably need at least 5 to get this going, I emailed thunder a little while back but never got a response, maybe they need a few more emails ?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I don't what to look stupid but what are Del-a-Lum bushings? Why are they better? How good are they?
Car: 93 240SX
Engine: LQ9
They're replacement lower control arm bushings for the front of our cars, made of machined aluminum, they resist flex much better than rubber or poly, have teflon sleeves and grease fittings, if you think about the load placed on your control arms, the choice is clear.
Car: 1992
Engine: 350TPI
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Im interested in going in with you guys for the most part..
Im having somewhat of a brain fart so you'll have to humor me now. I cant picture how the fitting would go in the lower control arms. Do you drill a small hole in the a-arm and then screw the fitting in?? After a couple days go by and this thread (with info on Del-a-Lum bushings) gets bigger I'll most likely give a yes or no answer as to whether Im in or not. Later..
Dan
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Dan
Car: 1984 Camaro Z28
Engine: Blueprint 383
Im interested in going in with you guys for the most part.. Im having somewhat of a brain fart so you'll have to humor me now. I cant picture how the fitting would go in the lower control arms. Do you drill a small hole in the a-arm and then screw the fitting in?? After a couple days go by and this thread (with info on Del-a-Lum bushings) gets bigger I'll most likely give a yes or no answer as to whether Im in or not. Later..
Craig
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Here is a pic of of Del-A-Lum bushing kit for my 87.
I bought these to use on my car, but first I'm going to reverse engineer them, make a few changes and hopefully improvements, and at some point down the road might produce them for sale.
They are a fairly good design, but anything you get from Global west is way over priced.
FYI-the bushings are not teflon. They are delrin. Hence the name Del (delrin) A-Lum (aluminum)
![](http://www.alloyspecialties.com/del-a-lum-1.jpg)
Does anybody have any pictures of Del-A-Lum bushings installed? Im curious to see what they look like installed.
Later..
Dan
Later..
Dan
Thirdgen89GTA
08-20-2015 03:11 PM
