That small canister on the brake booster vacuum line. What does it do?
What does that small cannister do, that sits in the rubber vacuum line from the brake booster to the engine manifold?
My mechanic removed it, saying I didnt need it.. But I still have it.. Should I put it back on?
Pretty sure its a check valve. So vacuum wont go back out of the booster. If your engine keeps good vacuum when its running, then no you dont need it, but I dont see why he would take it off, unless its broken.
1 Post
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: That small canister on the brake booster vacuum line. What does it do?
Thanks guys for the input.. ..I have recently installed a XE268 cam, brakes feel the same at idle etc.. but this canister is going back on first thing in the morning
Thanks again guys.
Thanks again guys.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
it is a filter so the crankcase fumes don't get into the booster and deteriorate the diaphram.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I wasn't aware there was a filter inside it but I do know it's a check valve. If the engine dies while driving, the check valve will hold vacuum in the booster for a couple of power assist brake applications. Once the vacuum is gone, braking becomes very difficult.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It should be a filter, the check valve should be the little plastc piece on the booster.
Car: 87 IROC L98
Oops. I stand corrected. The check valve is the piece that goes into the booster.
It's still a good idea to use the filter.
1992 Trans Am
05-10-2023 07:19 PM
theshackle
03-05-2017 06:37 PM
