LT1 rear end brake line question
1 Post
Car: 1992 RS
Engine: 406 Stealth Ram
I installed a Strange 12 bolt that originally came out of a 4thgen into my 92. My car originally had drum brakes, and new rear end is set up for Lt1 rear disc brakes. What I need to do is connect the calipers to the T fitting from my old brake system. I was planning on using my old hard lines that went to the wheel cylinders as a guide. I can buy brake line for the parts store, and re-use my old fittings at the T, but from there, I dont know what I need to do. On the other end of the hard steel line, I need a rubber hose with a banjo fitting on one end and a threaded fitting on the other. Do any of you happen to know the size/thread/type of the fittings on my old drum brakes? There is a hydraulic hose manufacturer close to where I work, and they can make the rubber hose for me as along as I know what size fittings the hose needs. I REALLY need to get the rear brakes working here, pleeeeaaaasee help me
I did this on my 91z28. I put a 4th gen disc rear in place of the old drum rear i had. The 4th gen rear already had the lines on it and I just connected them at the T fitting. Your car will have 1 brake line coming from the front. You should try going to the dealer and getting new replacemnt lines for the 10 bolt rear for the 4th gens. They will come pre bent and already have the proper banjo fittings on the ends. You just got to get them to thread into the T fitting and the calipers. Does this help you
1 Post
Car: 1992 RS
I ended up going to dealer for the rubber lines that go from the caliper to the hard steel line, then I bent my own lines and attached them to the T. I used the wrong flare, but it will work for a little while (I'm not even driving the car yet, just moving it up and down the driveway, lol). I'll eventually goto a junkyard and pick up some steel lines that are bent correctly, but for now, these will do. I was going to pick up the steel lines at the dealer as well, but the guiy said they dont come pre bent, just the correct length with fittings.. what kind of crap is that?!?
1 Post
Car: 1992 RS
Originally posted by _max_
hey Scott_92RS did you put a proportioning valve off you master or what did you do to power up your new rear discs
1 Post
Car: 1992 RS
Thats good to hear. If it turns out that my brakes work fine with the stock valve, I'll just keep in in there till I upgrade the fronts.
thank you for the input some say it wont work hehe but yours is working with oem master :hail: my son hooked me up with a 87 GTA booster and master from a wrecked car with oem discs gunna try that before the wildwood valve thanks again for the reply
hectre13
12-11-2023 08:14 AM
AkDrifted
08-17-2015 07:45 PM
1992 Trans Am
08-08-2015 08:16 PM
